HTC Vive Focus Facerest Replacement
  1. HTC Vive Focus Facerest Replacement, Remove the facerest cushion: step 1, image 1 of 3 HTC Vive Focus Facerest Replacement, Remove the facerest cushion: step 1, image 2 of 3 HTC Vive Focus Facerest Replacement, Remove the facerest cushion: step 1, image 3 of 3
    • Place your device upside-down on your work surface.
    • The facerest cushion is lightly held into place by seven plastic clips.
    • Use your fingers to gently pull the facerest cushion straight off of the facerest to remove it.
  2. HTC Vive Focus Facerest Replacement, Remove the facerest: step 2, image 1 of 1
    • Use a T5 Torx screwdriver to remove the eight 4.5 mm screws securing the facerest.
    • One of the screws will be covered by a tamper-evident sticker. Press the driver through the sticker to remove the screw.
  3. HTC Vive Focus Facerest Replacement: step 3, image 1 of 3 HTC Vive Focus Facerest Replacement: step 3, image 2 of 3 HTC Vive Focus Facerest Replacement: step 3, image 3 of 3
    • Insert an opening pick into the upper-left corner of the facerest.
    • Twist the opening pick to release the plastic clip securing the facerest.
    • Repeat for the upper-right corner.
    • Don't remove the facerest yet. It's still attached by the facerest sensor ribbon cable.
  4. HTC Vive Focus Facerest Replacement, Remove the facerest sensor: step 4, image 1 of 3 HTC Vive Focus Facerest Replacement, Remove the facerest sensor: step 4, image 2 of 3 HTC Vive Focus Facerest Replacement, Remove the facerest sensor: step 4, image 3 of 3
    • Carefully flip your device over.
    • Pull the facerest out just enough to access the screws securing the facerest sensor.
    • Don't put any strain on the facerest sensor ribbon cable.
    • During reassembly, make sure the facerest sensor ribbon cable is positioned between the lenses before reinstalling the facerest.
  5. HTC Vive Focus Facerest Replacement: step 5, image 1 of 1
    • Use a T5 Torx screwdriver to remove the two 2.4 mm screws securing the facerest sensor to the facerest.
  6. HTC Vive Focus Facerest Replacement: step 6, image 1 of 1
    • Remove the facerest.
Sam Omiotek
95,801 Reputation
290 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 259
