HTC Vive Head Strap Mounts Replacement
  1. HTC Vive Head Strap Mounts Replacement, Unscrew the head strap mounts: step 1, image 1 of 2 HTC Vive Head Strap Mounts Replacement, Unscrew the head strap mounts: step 1, image 2 of 2
    • Be sure to power down and disconnect your Vive before beginning.
    • Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
    • The mounts may fall off when the screws are removed, so be careful not to lose any parts.
  2. HTC Vive Head Strap Mounts Replacement, Remove the head strap mounts: step 2, image 1 of 2 HTC Vive Head Strap Mounts Replacement, Remove the head strap mounts: step 2, image 2 of 2
    • Remove the left head strap mount from the Vive.
  3. HTC Vive Head Strap Mounts Replacement, Separate the head strap mount components: step 3, image 1 of 2 HTC Vive Head Strap Mounts Replacement, Separate the head strap mount components: step 3, image 2 of 2
    • Pull the rubberized grip off of the head strap mount.
  4. HTC Vive Head Strap Mounts Replacement: step 4, image 1 of 3 HTC Vive Head Strap Mounts Replacement: step 4, image 2 of 3 HTC Vive Head Strap Mounts Replacement: step 4, image 3 of 3
    • Push the internal locking mechanism out of the grip.
  5. HTC Vive Head Strap Mounts Replacement: step 5, image 1 of 3 HTC Vive Head Strap Mounts Replacement: step 5, image 2 of 3 HTC Vive Head Strap Mounts Replacement: step 5, image 3 of 3
    • Repeat the previous three steps with the right head strap mount to remove it and separate its components.
2 other people completed this guide.
Adam O'Camb
208,958 Reputation
416 Guides authored
5 Comments
how do you pute the headset back to getther on the vive.
GreggTHhompson - Reply
how do you put the strape back on the right way im stuk i need some help with it.
Gregg Thompson - Reply
Anybody knows where i can get the part, that is removed in step 3? On the picture it stays with the head strap mount, but the headstrap is sold without it. Im espacily looking for the plastic part, where the screw goes through.
MrBesen - Reply
same, if u found it lemme know
auris -
same man, my headstrap mount and a tracker dongle broke and theres no way to replace it. fml
arte beatti - Reply
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 26
All Time: 3,091
