HTC Vive Pro 2 Head Strap Replacement
  1. HTC Vive Pro 2 Head Strap Replacement, Reposition the head strap: step 1, image 1 of 2 HTC Vive Pro 2 Head Strap Replacement, Reposition the head strap: step 1, image 2 of 2
    • Rotate the head strap forward as far as it will go.
  2. HTC Vive Pro 2 Head Strap Replacement, Unplug the All-In-One Cable: step 2, image 1 of 2 HTC Vive Pro 2 Head Strap Replacement, Unplug the All-In-One Cable: step 2, image 2 of 2
    • Unplug the All-In-One Cable from your headset.
  3. HTC Vive Pro 2 Head Strap Replacement, Remove the All-In-One Cable: step 3, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the All-In-One Cable: step 3, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the All-In-One Cable: step 3, image 3 of 3
    • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
    • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
  4. HTC Vive Pro 2 Head Strap Replacement, Remove the top strap: step 4, image 1 of 2 HTC Vive Pro 2 Head Strap Replacement, Remove the top strap: step 4, image 2 of 2
    • Separate the top strap from itself where the Velcro secures it.
  5. HTC Vive Pro 2 Head Strap Replacement: step 5, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement: step 5, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement: step 5, image 3 of 3
    • Peel back the Velcro securing the rear of the top strap.
    • Feed the top strap out through the head strap to partially remove it.
  6. HTC Vive Pro 2 Head Strap Replacement: step 6, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement: step 6, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement: step 6, image 3 of 3
    • Feed the top strap through the clip near the front of headset to fully remove it.
  7. HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: step 7, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: step 7, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: step 7, image 3 of 3
    • Peel off both front side foam pads to uncover the speaker wires.
  8. HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: step 8, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: step 8, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: step 8, image 3 of 3
    • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
    • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
  9. HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: step 9, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: step 9, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: step 9, image 3 of 3
    • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
  10. HTC Vive Pro 2 Head Strap Replacement, Remove the head strap: step 10, image 1 of 2 HTC Vive Pro 2 Head Strap Replacement, Remove the head strap: step 10, image 2 of 2
    • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
    • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
    • Four 3.9 mm screws (two on each side)
    • Two 4.1 mm screws (one on each side)
  11. HTC Vive Pro 2 Head Strap Replacement: step 11, image 1 of 1
    • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
  12. HTC Vive Pro 2 Head Strap Replacement: step 12, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement: step 12, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement: step 12, image 3 of 3
    • Thread the headphone speaker wires out through both ends of the head strap.
  13. HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: step 13, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: step 13, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: step 13, image 3 of 3
  14. HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: step 14, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: step 14, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: step 14, image 3 of 3
  15. HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: step 15, image 1 of 2 HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: step 15, image 2 of 2
  16. HTC Vive Pro 2 Head Strap Replacement, Remove the head strap: step 16, image 1 of 2 HTC Vive Pro 2 Head Strap Replacement, Remove the head strap: step 16, image 2 of 2
  17. HTC Vive Pro 2 Head Strap Replacement: step 17, image 1 of 1
  18. HTC Vive Pro 2 Head Strap Replacement: step 18, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement: step 18, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement: step 18, image 3 of 3
Alex Diaz-Kokaisl
163,345 Reputation
770 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,570 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 23
All Time: 61
