HTC Vive XR Elite Heat Sink Replacement
  1. HTC Vive XR Elite Heat Sink Replacement, Prepare your Vive XR Elite for disassembly: step 1, image 1 of 1
    • Before starting this repair, discharge the batteries in your headset below 25%. A charged battery may leak dangerous chemicals or catch fire if damaged.
    • Playing Half Life: Alyx will do the trick!
    • The Vive XR Elite has a proximity sensor that puts the headset in standby mode to save battery when it isn't in use. To drain the battery faster you'll need to use the headset.
  2. HTC Vive XR Elite Heat Sink Replacement, Disconnect the USB-C power cable: step 2, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Disconnect the USB-C power cable: step 2, image 2 of 2
    • Disconnect the USB-C power cable.
  3. HTC Vive XR Elite Heat Sink Replacement, Disconnect the battery cradle: step 3, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Disconnect the battery cradle: step 3, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Disconnect the battery cradle: step 3, image 3 of 3
    • Press the release button on the right battery cradle temple slot.
    • Pull the battery cradle away from the right temple slot to disconnect it.
  4. HTC Vive XR Elite Heat Sink Replacement: step 4, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement: step 4, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement: step 4, image 3 of 3
    • Repeat the previous step for the left temple slot.
  5. HTC Vive XR Elite Heat Sink Replacement, Separate the headset and battery cradle: step 5, image 1 of 1
    • Separate the headset and battery cradle.
  6. HTC Vive XR Elite Heat Sink Replacement, Remove the face cushion: step 6, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Remove the face cushion: step 6, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Remove the face cushion: step 6, image 3 of 3
    • The face cushion is attached to the headset with two magnets. You'll feel the pull of the magnets as you remove it.
    • Grip the middle of the face cushion with your fingers and pull back to remove it.
  7. HTC Vive XR Elite Heat Sink Replacement, Remove the screw covers: step 7, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Remove the screw covers: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to remove the six screw covers from the right temple.
  8. HTC Vive XR Elite Heat Sink Replacement, Unfasten the right temple: step 8, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Unfasten the right temple: step 8, image 2 of 2
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two right temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the right hinge cover.
  9. HTC Vive XR Elite Heat Sink Replacement, Remove the outer hinge cover: step 9, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Remove the outer hinge cover: step 9, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Remove the outer hinge cover: step 9, image 3 of 3
    • Insert the flat end of a spudger in the gap between the right outer and inner hinge covers.
    • Slide the spudger along the gap to separate the clips securing the outer hinge cover.
    • Remove the outer hinge cover.
  10. HTC Vive XR Elite Heat Sink Replacement, Remove the outer temple: step 10, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Remove the outer temple: step 10, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Remove the outer temple: step 10, image 3 of 3
    • Insert the flat end of a spudger in the gap between the outer and inner temple.
    • Slide the spudger along the gap to separate the clips securing the outer temple.
  11. HTC Vive XR Elite Heat Sink Replacement: step 11, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement: step 11, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement: step 11, image 3 of 3
    • Slide the top of the outer temple out of its slot in the hinge.
  12. HTC Vive XR Elite Heat Sink Replacement: step 12, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement: step 12, image 2 of 2
    Tesa 61395 Tape
    $6.99
    Buy
    • The speaker is lightly adhered to the outer temple.
    • Rotate the outer temple towards you to access the speaker.
    • Slide the flat end of a spudger under the speaker to separate its adhesive.
    • During reassembly, if your speaker adhesive isn't sticky, use double-sided tape to re-adhere the speaker to the outer temple.
  13. HTC Vive XR Elite Heat Sink Replacement: step 13, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement: step 13, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement: step 13, image 3 of 3
    • Thread the outer temple off of the USB‑C cable and remove it.
  14. HTC Vive XR Elite Heat Sink Replacement: step 14, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement: step 14, image 2 of 2
    • Pull the inner temple out of its slot in the hinge and remove it.
  15. HTC Vive XR Elite Heat Sink Replacement, Peel the hinge tape: step 15, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Peel the hinge tape: step 15, image 2 of 2
    • Use tweezers to peel back the black tape covering one of the inner hinge cover screws.
  16. HTC Vive XR Elite Heat Sink Replacement, Unfasten the inner hinge cover: step 16, image 1 of 1
    • Use a T5 Torx screwdriver to remove the two screws securing the inner hinge cover:
    • One 3.1 mm‑long screw
    • One 4.9 mm‑long screw
  17. HTC Vive XR Elite Heat Sink Replacement, Remove the inner hinge cover: step 17, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Remove the inner hinge cover: step 17, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Remove the inner hinge cover: step 17, image 3 of 3
    • Rotate the inner hinge cover off its groove in the frame.
    • Thread the inner hinge cover off of the USB-C and speaker cables and remove it.
  18. HTC Vive XR Elite Heat Sink Replacement, Remove the screw covers: step 18, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Remove the screw covers: step 18, image 2 of 2
    Buy
    • Use tweezers to remove the six screw covers from the left temple.
  19. HTC Vive XR Elite Heat Sink Replacement, Unfasten the left temple: step 19, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Unfasten the left temple: step 19, image 2 of 2
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two left temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the left hinge cover.
  20. HTC Vive XR Elite Heat Sink Replacement, Remove the outer hinge cover: step 20, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Remove the outer hinge cover: step 20, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Remove the outer hinge cover: step 20, image 3 of 3
    • Insert the flat end of a spudger in the gap between the left outer and inner hinge covers.
  21. HTC Vive XR Elite Heat Sink Replacement, Remove the left temple: step 21, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Remove the left temple: step 21, image 2 of 2
    • Pull the left temple out of its slot in the hinge.
    • Don't try to fully remove it yet, as it's still connected by a cable.
  22. HTC Vive XR Elite Heat Sink Replacement: step 22, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement: step 22, image 2 of 2
    • Slide the spudger along the gap to separate the plastic clips securing the outer temple.
  23. HTC Vive XR Elite Heat Sink Replacement: step 23, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement: step 23, image 2 of 2
    • Pull the outer temple off of its inner half to completely release its plastic clips.
  24. HTC Vive XR Elite Heat Sink Replacement: step 24, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement: step 24, image 2 of 2
    Tesa 61395 Tape
    $6.99
    Buy
    • Let the speaker rest next to the headset before continuing.
    • During reassembly, if your speaker adhesive isn't sticky, use Tesa 61395 Tape to re-adhere the speaker to the outer temple.
  25. HTC Vive XR Elite Heat Sink Replacement, Peel the hinge tape: step 25, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Peel the hinge tape: step 25, image 2 of 2
  26. HTC Vive XR Elite Heat Sink Replacement, Unfasten the inner hinge cover: step 26, image 1 of 1
    • One 3.5 mm‑long screw
  27. HTC Vive XR Elite Heat Sink Replacement, Reposition the inner hinge cover: step 27, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Reposition the inner hinge cover: step 27, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Reposition the inner hinge cover: step 27, image 3 of 3
    • Don't fully remove the inner hinge cover, as it's connected by the volume button cable.
    • Let the cover hang off its volume button cable for now.
  28. HTC Vive XR Elite Heat Sink Replacement, Unfasten the face plate: step 28, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Unfasten the face plate: step 28, image 2 of 2
    • Use a T5 Torx screwdriver to remove the 12 screws securing the face plate:
    • Six 3.5 mm‑long screws
    • Four 4.9 mm‑long screws
    • Two 6.5 mm‑long screws
    • There are two magnets at the top corners of the face plate. As you remove nearby screws, they might stick to them.
  29. HTC Vive XR Elite Heat Sink Replacement, Unclip the face cover: step 29, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Unclip the face cover: step 29, image 2 of 2
    • Insert the flat end of the spudger in the gap between the frame and the bottom right corner of the face cover.
    • Pry up with the spudger to release the clips securing the face cover.
  30. HTC Vive XR Elite Heat Sink Replacement: step 30, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement: step 30, image 2 of 2
    • Repeat the prying process for the middle and bottom left portions of the face cover.
  31. HTC Vive XR Elite Heat Sink Replacement, Reposition the face cover: step 31, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Reposition the face cover: step 31, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Reposition the face cover: step 31, image 3 of 3
    • Don't fully remove the face cover completely, as it's connected by the proximity sensor cable.
    • Lift the face cover and rotate it over the top of the frame.
    • Lay the face cover face up before continuing.
  32. HTC Vive XR Elite Heat Sink Replacement, Unfasten the proximity sensor: step 32, image 1 of 1
    • Use a T5 Torx screwdriver to remove the two 3.3 mm‑long screws securing the proximity sensor cable.
  33. HTC Vive XR Elite Heat Sink Replacement, Remove the face cover: step 33, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Remove the face cover: step 33, image 2 of 2
    • Remove the face cover.
  34. HTC Vive XR Elite Heat Sink Replacement, Reposition the lens assembly: step 34, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Reposition the lens assembly: step 34, image 2 of 2
    • Pull the two lenses outward so they're as far apart as possible.
  35. HTC Vive XR Elite Heat Sink Replacement, Unfasten the lens assembly: step 35, image 1 of 1
    • Use a T5 Torx screwdriver to remove the four screws securing the lens assembly:
    • Three 4.9 mm‑long screws
    • One 3.3 mm‑long screw
  36. HTC Vive XR Elite Heat Sink Replacement, Remove the brackets: step 36, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Remove the brackets: step 36, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Remove the brackets: step 36, image 3 of 3
    Buy
    • The screw brackets are secured with clips and adhesive.
    • Use tweezers to pull the left screw bracket of its post in the frame.
    • This may require some force. Be careful not to scratch any surrounding components.
    • Repeat this process for the right bracket.
    • During reassembly, use tweezers to align the brackets on their posts. Press down with the flat end of a spudger to engage and re-adhere the clips.
  37. HTC Vive XR Elite Heat Sink Replacement, Reposition the lens assembly: step 37, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Reposition the lens assembly: step 37, image 2 of 2
    • Lift the bottom of the lens assembly up to separate the bottom rails from their slots in the frame.
  38. HTC Vive XR Elite Heat Sink Replacement: step 38, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement: step 38, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement: step 38, image 3 of 3
    • Pull the lens assembly upwards to separate the top rails from their slots in the frame.
    • Rotate the lens assembly towards the top of the frame so it sits upright with its cable connectors exposed.
  39. HTC Vive XR Elite Heat Sink Replacement, Unfasten the lens assembly cables: step 39, image 1 of 1
    • Use a T5 Torx screwdriver to remove the four 3.4 mm‑long screws securing the lens assembly cables.
  40. HTC Vive XR Elite Heat Sink Replacement, Disconnect the lens assembly cables: step 40, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Disconnect the lens assembly cables: step 40, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Disconnect the lens assembly cables: step 40, image 3 of 3
    • Use the flat end of a spudger to pry up and disconnect the lens assembly cable connector.
    • Repeat this procedure for the other connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  41. HTC Vive XR Elite Heat Sink Replacement, Remove the lens assembly: step 41, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Remove the lens assembly: step 41, image 2 of 2
    • Lift up and remove the lens assembly.
  42. HTC Vive XR Elite Heat Sink Replacement, Reassembly information: step 42, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Reassembly information: step 42, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Reassembly information: step 42, image 3 of 3
    • The next four steps demonstrate how to secure the lens assembly to the frame during reassembly.
    • In order for the lens assembly to rest in the frame properly, it needs to align with a peg in the IPD (interpupillary distance) slider.
    • Before reinstalling the lens assembly, push the IPD slider to its right-most position.
  43. HTC Vive XR Elite Heat Sink Replacement: step 43, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement: step 43, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement: step 43, image 3 of 3
    • Pull the lens assembly outward until its plastic clips sit close to the end of the top rails.
    • You may need to push and pull the top rail so it sits evenly across the plastic clips.
  44. HTC Vive XR Elite Heat Sink Replacement: step 44, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement: step 44, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement: step 44, image 3 of 3
    • Push the bottom rails inwards as far as they will go.
  45. HTC Vive XR Elite Heat Sink Replacement: step 45, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement: step 45, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement: step 45, image 3 of 3
    • To secure the lens assembly into the frame:
    • Slide the top left rail into its slot.
    • Align the other rails.
    • Press the lens assembly into place, making sure to realign the center peg.
  46. HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 46, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 46, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 46, image 3 of 3
    Buy
  47. HTC Vive XR Elite Heat Sink Replacement: step 47, image 1 of 1
    • Peel off the yellow tape covering the proximity sensor connector.
  48. HTC Vive XR Elite Heat Sink Replacement, Disconnect the proximity sensor: step 48, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Disconnect the proximity sensor: step 48, image 2 of 2
    • Use the point of a spudger to lift up the locking flap on the proximity sensor ZIF connector.
  49. HTC Vive XR Elite Heat Sink Replacement: step 49, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement: step 49, image 2 of 2
    • Use tweezers to pull the proximity sensor cable out of its slot in the motherboard.
  50. HTC Vive XR Elite Heat Sink Replacement, Remove the proximity sensor: step 50, image 1 of 1
    • Remove the proximity sensor.
  51. HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 51, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 51, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 51, image 3 of 3
    • Peel off the yellow tape covering the motion sensor cable.
  52. HTC Vive XR Elite Heat Sink Replacement, Unfasten the motion sensor: step 52, image 1 of 1
    • Use a T5 Torx screwdriver to remove the two 3.4 mm‑long screws securing the motion sensor.
  53. HTC Vive XR Elite Heat Sink Replacement, Reposition the motion sensor: step 53, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Reposition the motion sensor: step 53, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Reposition the motion sensor: step 53, image 3 of 3
    • Don't try to fully remove the motion sensor yet, as it's still connected by a cable.
    • Lift the motion sensor off its pegs in the frame.
    • Flip over the motion sensor and lay it on the frame before continuing.
  54. HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 54, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 54, image 2 of 2
    • Peel off the yellow tape covering the motion sensor cable connector.
  55. HTC Vive XR Elite Heat Sink Replacement, Disconnect the motion sensor: step 55, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Disconnect the motion sensor: step 55, image 2 of 2
    • Use the point of a spudger to lift up the locking flap on the motion sensor ZIF connector.
  56. HTC Vive XR Elite Heat Sink Replacement, Remove the motion sensor: step 56, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Remove the motion sensor: step 56, image 2 of 2
    Buy
    • Use tweezers to pull the motion sensor cable connector out of its slot.
    • Remove the motion sensor.
  57. HTC Vive XR Elite Heat Sink Replacement, Disconnect the right speaker: step 57, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Disconnect the right speaker: step 57, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Disconnect the right speaker: step 57, image 3 of 3
    Buy
    • Use tweezers to pull the right speaker connector out of its socket.
    • If you're having trouble, try rocking the connector side-to-side to help loosen it.
  58. HTC Vive XR Elite Heat Sink Replacement, Remove the right speaker: step 58, image 1 of 1
    • Remove the right speaker.
  59. HTC Vive XR Elite Heat Sink Replacement, Disconnect the left speaker: step 59, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Disconnect the left speaker: step 59, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Disconnect the left speaker: step 59, image 3 of 3
    • Use tweezers to pull the left speaker connector out of its socket.
  60. HTC Vive XR Elite Heat Sink Replacement, Remove the left speaker: step 60, image 1 of 1
    • Remove the left speaker.
  61. HTC Vive XR Elite Heat Sink Replacement, Separate the volume button cable: step 61, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Separate the volume button cable: step 61, image 2 of 2
    • The volume button cable is lightly adhered to the left inner hinge cover.
    • Insert one arm of your tweezers between the volume button cable and the hinge cover.
    • Pry away from the hinge cover to separate the adhesive.
  62. HTC Vive XR Elite Heat Sink Replacement: step 62, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement: step 62, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement: step 62, image 3 of 3
    • Use your tweezers to pull the volume button cable out of its slot in the hinge cover.
  63. HTC Vive XR Elite Heat Sink Replacement, Disconnect the bottom left antenna: step 63, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Disconnect the bottom left antenna: step 63, image 2 of 2
    • Use one arm of your tweezers to pry up and disconnect the bottom left antenna cable.
    • During reassembly, these can be tricky to reconnect. Hold the connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  64. HTC Vive XR Elite Heat Sink Replacement, Reposition the bottom left antenna cable: step 64, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Reposition the bottom left antenna cable: step 64, image 2 of 2
  65. HTC Vive XR Elite Heat Sink Replacement, Unfasten the motion sensor bracket: step 65, image 1 of 1
    • Use a T5 Torx screwdriver to remove the two 4.9 mm‑long screws securing the motion sensor bracket.
  66. HTC Vive XR Elite Heat Sink Replacement, Remove the motion sensor bracket: step 66, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Remove the motion sensor bracket: step 66, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Remove the motion sensor bracket: step 66, image 3 of 3
    • Lift the motion sensor off its pegs on the motherboard.
    • Remove the motion sensor bracket.
  67. HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 67, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 67, image 2 of 2
    • Use tweezers to peel back the gray conductive tape covering the left side‑camera ZIF connector.
  68. HTC Vive XR Elite Heat Sink Replacement: step 68, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement: step 68, image 2 of 2
    • Use tweezers to peel off the black tape covering the left side‑camera ZIF connector.
  69. HTC Vive XR Elite Heat Sink Replacement, Disconnect the left side camera: step 69, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Disconnect the left side camera: step 69, image 2 of 2
    • Use flat end of a spudger to lift up the locking flap on the left side‑camera ZIF connector.
  70. HTC Vive XR Elite Heat Sink Replacement: step 70, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement: step 70, image 2 of 2
    • Use tweezers to pull the left side‑camera cable connector out of its slot in the motherboard.
  71. HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 71, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 71, image 2 of 2
    • Use tweezers to peel back the gray conductive tape covering the left tracking camera ZIF connector.
  72. HTC Vive XR Elite Heat Sink Replacement: step 72, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement: step 72, image 2 of 2
    • Use tweezers to peel off the black tape covering the left tracking camera ZIF connector.
  73. HTC Vive XR Elite Heat Sink Replacement, Disconnect the left tracking camera: step 73, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Disconnect the left tracking camera: step 73, image 2 of 2
    • Use a spudger to lift up the locking flap on the left tracking camera ZIF connector.
  74. HTC Vive XR Elite Heat Sink Replacement: step 74, image 1 of 1
    • Use tweezers to pull the left tracking camera cable connector out of its slot in the motherboard.
  75. HTC Vive XR Elite Heat Sink Replacement, Disconnect the antennas: step 75, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Disconnect the antennas: step 75, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Disconnect the antennas: step 75, image 3 of 3
  76. HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 76, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 76, image 2 of 2
  77. HTC Vive XR Elite Heat Sink Replacement: step 77, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement: step 77, image 2 of 2
    • Use tweezers to peel off the black tape covering the pass-through camera ZIF connector.
  78. HTC Vive XR Elite Heat Sink Replacement, Disconnect the pass-through camera: step 78, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Disconnect the pass-through camera: step 78, image 2 of 2
    • Use a spudger to lift up the locking flap on the pass-through camera ZIF connector.
  79. HTC Vive XR Elite Heat Sink Replacement: step 79, image 1 of 1
    • Use tweezers to pull the pass-through camera cable connector out of its slot in the motherboard.
  80. HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 80, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 80, image 2 of 2
  81. HTC Vive XR Elite Heat Sink Replacement, Disconnect the microphone: step 81, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Disconnect the microphone: step 81, image 2 of 2
    • Use the point of a spudger to lift up the locking flap on the microphone ZIF connector.
  82. HTC Vive XR Elite Heat Sink Replacement: step 82, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement: step 82, image 2 of 2
    • Use tweezers to pull the microphone cable connector out of its slot in the motherboard.
  83. HTC Vive XR Elite Heat Sink Replacement, Disconnect the depth sensor: step 83, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Disconnect the depth sensor: step 83, image 2 of 2
    • Use tweezers to pull the depth sensor cable connector out of its slot in the motherboard.
  84. HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 84, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 84, image 2 of 2
    • Use tweezers to peel back the gray conductive tape covering the right tracking camera ZIF connector.
  85. HTC Vive XR Elite Heat Sink Replacement: step 85, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement: step 85, image 2 of 2
    • Use tweezers to peel off the black tape covering the right tracking camera ZIF connector.
  86. HTC Vive XR Elite Heat Sink Replacement, Disconnect the right tracking camera: step 86, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Disconnect the right tracking camera: step 86, image 2 of 2
    • Use a spudger to lift up the locking flap on the right tracking camera ZIF connector.
  87. HTC Vive XR Elite Heat Sink Replacement: step 87, image 1 of 1
    • Use tweezers to pull the right tracking camera cable connector out of its slot.
  88. HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 88, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 88, image 2 of 2
    • Use tweezers to peel back the gray conductive tape covering the right side‑camera ZIF connector.
  89. HTC Vive XR Elite Heat Sink Replacement: step 89, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement: step 89, image 2 of 2
    • Use tweezers to peel off the black tape covering the right side‑camera ZIF connector.
  90. HTC Vive XR Elite Heat Sink Replacement, Disconnect the right side camera: step 90, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Disconnect the right side camera: step 90, image 2 of 2
    • Use a spudger to lift up the locking flap on the right side-camera ZIF connector.
  91. HTC Vive XR Elite Heat Sink Replacement: step 91, image 1 of 1
    • Use tweezers to pull the right side‑camera cable connector out of its slot.
  92. HTC Vive XR Elite Heat Sink Replacement, Unfasten the motherboard frame: step 92, image 1 of 1
    • Use a T5 Torx screwdriver to remove the two 4.9 mm‑long screws securing the motherboard frame.
  93. HTC Vive XR Elite Heat Sink Replacement, Tape the cables: step 93, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Tape the cables: step 93, image 2 of 2
    • Use tape with light adhesive, such as painter's tape, to keep the left and right side cables away from the motherboard.
    • The cables near the top edge need slack for the motherboard to rest properly in the frame. Avoid taping them tightly—or avoid taping them altogether.
  94. HTC Vive XR Elite Heat Sink Replacement, Disconnect the power button: step 94, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Disconnect the power button: step 94, image 2 of 2
    • Lift the power button out of its slot in the frame.
    • Don't remove the button completely, as it's still attached by a cable.
  95. HTC Vive XR Elite Heat Sink Replacement, Remove the IPD slider: step 95, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Remove the IPD slider: step 95, image 2 of 2
    • Press down the bottom right corner of the motherboard so its edge rests under the IPD slider.
  96. HTC Vive XR Elite Heat Sink Replacement: step 96, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement: step 96, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement: step 96, image 3 of 3
    • While pressing down on the motherboard, push the IPD slider out of its slot in the frame.
    • Remove the IPD slider.
  97. HTC Vive XR Elite Heat Sink Replacement, Remove the motherboard assembly: step 97, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Remove the motherboard assembly: step 97, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Remove the motherboard assembly: step 97, image 3 of 3
    • Grip the USB-C port with one hand and the right side of the frame with the other.
    • Pull the frame outward while lifting the motherboard assembly until it clears its slot next to the right side‑camera.
    • Use a spudger to pry up the motherboard assembly until its right side completely clears the frame.
  98. HTC Vive XR Elite Heat Sink Replacement: step 98, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement: step 98, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement: step 98, image 3 of 3
    • Pull the right side of the motherboard assembly toward the bottom edge of the device to separate it from the frame.
    • Remove the motherboard assembly.
    • During reassembly, make sure the cables stay above the motherboard assembly as you reinstall it.
  99. HTC Vive XR Elite Heat Sink Replacement, Disconnect the battery: step 99, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Disconnect the battery: step 99, image 2 of 2
    • Flip the motherboard assembly over so the fan is facing upward.
    • Use the point of a spudger to pry up and disconnect the headset battery press connector.
  100. HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 100, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Peel the tape: step 100, image 2 of 2
    • Peel back the black tape next to the fan covering the heat sink screw.
  101. HTC Vive XR Elite Heat Sink Replacement, Unclip the heat sink cover: step 101, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Unclip the heat sink cover: step 101, image 2 of 2
    • Pull up the air guide to unclip it from the motherboard frame.
  102. HTC Vive XR Elite Heat Sink Replacement, Unfasten the heat sink: step 102, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Unfasten the heat sink: step 102, image 2 of 2
    • Take care not to puncture or bend the battery—it can leak dangerous chemicals and/or catch fire.
    • Use a T5 Torx screwdriver to remove the three screws securing the heat sink:
    • Two 3.4 mm‑long screws
    • Flip the motherboard assembly over so the USB‑C port is facing upward.
    • Use a T5 Torx screwdriver to remove the 3.5 mm‑long screw securing the motherboard frame.
  103. HTC Vive XR Elite Heat Sink Replacement, Remove the heat sink bracket: step 103, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Remove the heat sink bracket: step 103, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Remove the heat sink bracket: step 103, image 3 of 3
    • A metal bracket between the heat sink and the motherboard frame secures the heat sink.
    • Pull the bottom left corner of the motherboard frame away from the heat sink until the metal bracket falls out.
    • Remove the heat sink bracket.
  104. HTC Vive XR Elite Heat Sink Replacement, Remove the heat sink: step 104, image 1 of 2 HTC Vive XR Elite Heat Sink Replacement, Remove the heat sink: step 104, image 2 of 2
    • The heat sink might stick to the motherboard depending on the age of your device and the condition of the thermal paste. You'll probably feel resistance when performing this step.
    • Lift the arm of the heat sink upwards until you feel the thermal paste separate from the heat sink.
  105. HTC Vive XR Elite Heat Sink Replacement: step 105, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement: step 105, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement: step 105, image 3 of 3
    • Guide the heat sink out of its slot in the motherboard frame.
    • You may have to slightly bend the left side of the motherboard frame upward to free the heat sink.
  106. HTC Vive XR Elite Heat Sink Replacement, Reassembly information: step 106, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement, Reassembly information: step 106, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement, Reassembly information: step 106, image 3 of 3
    • During reassembly, perform the following to realign the heat sink:
    • Place the heat sink bracket on its two alignment pegs in the motherboard frame.
    • Thread the arm of the heat sink through the gap in the top of the motherboard frame.
    • Place the square portion of the heat sink on the heat sink bracket.
  107. HTC Vive XR Elite Heat Sink Replacement: step 107, image 1 of 3 HTC Vive XR Elite Heat Sink Replacement: step 107, image 2 of 3 HTC Vive XR Elite Heat Sink Replacement: step 107, image 3 of 3
    • During reassembly, perform the following to reapply thermal paste:
    • Use the flat end of a spudger to scrape off the thermal paste on the processor.
    • Follow this guide to clean the processor and replace the thermal paste.
    • The HTC Vive XR Elite uses a special viscous thermal paste. Regular thermal paste won’t provide proper cooling. Make sure to use an appropriate thermal like K5 Pro to replace the old thermal paste.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
129,318 Reputation
600 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,072 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 64
