HTC Windows Phone 8S Logic Board Replacement
Video Overview
  1. HTC Windows Phone 8S Logic Board Replacement, Loudspeaker: step 1, image 1 of 3 HTC Windows Phone 8S Logic Board Replacement, Loudspeaker: step 1, image 2 of 3 HTC Windows Phone 8S Logic Board Replacement, Loudspeaker: step 1, image 3 of 3
    • Switch off the phone.
    • Remove the SIM / memory card cover.
    • Remove any SIM and memory cards.
    • Use screwdriver torx T5 and unscrew the two screws at the bottom of the battery / back cover.
  2. HTC Windows Phone 8S Logic Board Replacement: step 2, image 1 of 3 HTC Windows Phone 8S Logic Board Replacement: step 2, image 2 of 3 HTC Windows Phone 8S Logic Board Replacement: step 2, image 3 of 3
    • Use a plastic tool and slowly separate the back cover.
    • The loudspeaker is inside on the back cover.
  3. HTC Windows Phone 8S Logic Board Replacement, Battery: step 3, image 1 of 3 HTC Windows Phone 8S Logic Board Replacement, Battery: step 3, image 2 of 3 HTC Windows Phone 8S Logic Board Replacement, Battery: step 3, image 3 of 3
    • Use a Phillips #0 screwdriver and remove the 4x silver screws.
    • With a plastic tool carefully separate the battery from the logic board.
  4. HTC Windows Phone 8S Logic Board Replacement: step 4, image 1 of 3 HTC Windows Phone 8S Logic Board Replacement: step 4, image 2 of 3 HTC Windows Phone 8S Logic Board Replacement: step 4, image 3 of 3
    • The battery connector is under the middle frame. Remove it and disconnect the battery.
    • Model: BM59100 / 3,8VDC / 1700mAh
  5. HTC Windows Phone 8S Logic Board Replacement, Flex Cables: step 5, image 1 of 3 HTC Windows Phone 8S Logic Board Replacement, Flex Cables: step 5, image 2 of 3 HTC Windows Phone 8S Logic Board Replacement, Flex Cables: step 5, image 3 of 3
    • Remove the USB dock connector metal plate.
    • Open flex cable connectors:
    • LCD display flex cable
    • Menu buttons flex cable
    • Volume buttons flex cable
    • Touch screen flex cable
    • Power button flex cable
    • Pick up the vibrating motor and take out all flex cables except the LCD display flex cable.
  6. HTC Windows Phone 8S Logic Board Replacement, Logic Board Removal: step 6, image 1 of 3 HTC Windows Phone 8S Logic Board Replacement, Logic Board Removal: step 6, image 2 of 3 HTC Windows Phone 8S Logic Board Replacement, Logic Board Removal: step 6, image 3 of 3
    • The logic board is secured to the display frame by two locking clips.
    • Use a plastic tool to release it.
    • Now remove the LCD display flex cable from its connector.
  7. HTC Windows Phone 8S Logic Board Replacement, Logic Board / Main Board: step 7, image 1 of 2 HTC Windows Phone 8S Logic Board Replacement, Logic Board / Main Board: step 7, image 2 of 2
    • HTC Windows Phone 8S Logic Board.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 1,047
