HTC Wizard 100 Speakers Replacement
  1. HTC Wizard 100 Speakers Replacement, Battery: step 1, image 1 of 2 HTC Wizard 100 Speakers Replacement, Battery: step 1, image 2 of 2
    • Power the phone off.
    • Use your thumb to gently press downward and away from the camera to remove the battery cover.
  2. HTC Wizard 100 Speakers Replacement: step 2, image 1 of 2 HTC Wizard 100 Speakers Replacement: step 2, image 2 of 2
    • Pull on the plastic tab to release the battery.
  3. HTC Wizard 100 Speakers Replacement, Back Case: step 3, image 1 of 2 HTC Wizard 100 Speakers Replacement, Back Case: step 3, image 2 of 2
    • Use a plastic opening tool to remove the camera cover.
    • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
    • Lift the camera cover off of the phone.
  4. HTC Wizard 100 Speakers Replacement: step 4, image 1 of 1
    • Remove the stylus from the phone.
    • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
    • One of the screws might be under a sticker, which will void your warranty.
  5. HTC Wizard 100 Speakers Replacement: step 5, image 1 of 3 HTC Wizard 100 Speakers Replacement: step 5, image 2 of 3 HTC Wizard 100 Speakers Replacement: step 5, image 3 of 3
    • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
    • If your phone contains a memory card, you may want to remove it before proceeding with this step.
    • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
    • Lift the back case off completely.
    • The speakers might be dangling and unsecured.
  6. HTC Wizard 100 Speakers Replacement, Speakers: step 6, image 1 of 2 HTC Wizard 100 Speakers Replacement, Speakers: step 6, image 2 of 2
    • Grip the speaker connector with your thumb and finger and gently pull up.
    • Repeat for 2nd speaker.
Taylor Stone
45 Reputation
2 Guides authored
Cal Poly, Team 20-28, Maness Fall 2011 Member of Cal Poly, Team 20-28, Maness Fall 2011
CPSU-MANESS-F11S20G28
4 Members
15 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 578
