HTC myTouch 3G Motherboard Replacement
  1. HTC myTouch 3G Motherboard Replacement, Remove the Cover: step 1, image 1 of 2 HTC myTouch 3G Motherboard Replacement, Remove the Cover: step 1, image 2 of 2
    • Press both thumbs on each side of the upper corners, and apply pressure in a downward motion.
    • While applying downward pressure, slide the back cover down and off the phone.
  2. HTC myTouch 3G Motherboard Replacement, Remove Battery and SIM Card: step 2, image 1 of 2 HTC myTouch 3G Motherboard Replacement, Remove Battery and SIM Card: step 2, image 2 of 2
    • Remove the battery.
    • Remove the SIM card.
  3. HTC myTouch 3G Motherboard Replacement, Remove SD Card: step 3, image 1 of 1
    • Push the SD card in to eject it.
    • Pull the SD card out.
  4. HTC myTouch 3G Motherboard Replacement, Remove Back Panel Screws: step 4, image 1 of 2 HTC myTouch 3G Motherboard Replacement, Remove Back Panel Screws: step 4, image 2 of 2
    • Remove the four 6 mm T5 Torx screws from the four corners on the back of the phone.
    • Remove the two 4 mm T5 Torx screws from the middle of the back of the phone.
  5. HTC myTouch 3G Motherboard Replacement, Access the Motherboard: step 5, image 1 of 2 HTC myTouch 3G Motherboard Replacement, Access the Motherboard: step 5, image 2 of 2
    • Pull out the antenna cover to access the motherboard.
  6. HTC myTouch 3G Motherboard Replacement, Dislodge the Back Plate: step 6, image 1 of 2 HTC myTouch 3G Motherboard Replacement, Dislodge the Back Plate: step 6, image 2 of 2
    • Insert a spudger into the gap between the frame and cover. Push downward with the spudger to separate the back plate from the phone.
    • With the spudger in the gap between the frame and cover, move the spudger around the edge of the of the phone to finish removing the back plate.
  7. HTC myTouch 3G Motherboard Replacement, Remove Back Screws: step 7, image 1 of 2 HTC myTouch 3G Motherboard Replacement, Remove Back Screws: step 7, image 2 of 2
    • Remove the 3 mm Phillips screw located on the side of the bottom left-hand corner of the phone.
    • Remove the 3 mm Phillips screw located on the top right-hand corner of the phone.
    • Do not remove any of the screws located on the actual circuit boards.
  8. HTC myTouch 3G Motherboard Replacement, Separate the Circuit Board: step 8, image 1 of 3 HTC myTouch 3G Motherboard Replacement, Separate the Circuit Board: step 8, image 2 of 3 HTC myTouch 3G Motherboard Replacement, Separate the Circuit Board: step 8, image 3 of 3
    • Place a finger between the circuit board and front cover, and lift the circuit board gently.
    • Separate the circuit board from the front cover and screen to access the ribbon cable holding them together. Detach the ribbon cable.
    • Finish separating the circuit board from the front panel.
2 other people completed this guide.
Tony Tran
381 Reputation
3 Guides authored
Cal Poly, Team 2-9, Propen Fall 2012 Member of Cal Poly, Team 2-9, Propen Fall 2012
CPSU-PROPEN-F12S2G9
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 16
All Time: 1,520
