HTC myTouch 3G Trackball Replacement
  1. HTC myTouch 3G Trackball Replacement, Trackball: step 1, image 1 of 3 HTC myTouch 3G Trackball Replacement, Trackball: step 1, image 2 of 3 HTC myTouch 3G Trackball Replacement, Trackball: step 1, image 3 of 3
    • Slide the back cover down to remove it.
    • Lift and remove the battery. Then remove the SIM card by sliding it out of its slot.
    • Locate SD card on the lower right. Press in to eject and remove it.
  2. HTC myTouch 3G Trackball Replacement: step 2, image 1 of 2 HTC myTouch 3G Trackball Replacement: step 2, image 2 of 2
    • Remove the four 6-mm Torx screws located at the corners of the phone and set them aside.
    • Remove the two 4-mm Torx screws located at the two long sides toward the middle of the phone. Set them aside.
    • Keep the two sets of screws separated. This will ensure correct placement of the screws during reassembly.
  3. HTC myTouch 3G Trackball Replacement: step 3, image 1 of 3 HTC myTouch 3G Trackball Replacement: step 3, image 2 of 3 HTC myTouch 3G Trackball Replacement: step 3, image 3 of 3
    • Use a pry tool or your fingers to remove the antenna cover and antenna component from the bottom of the phone.
    • Insert a pry tool or your finger nail into the gap along the edge of the phone. Lift around the edges to loosen and remove the back plate.
  4. HTC myTouch 3G Trackball Replacement: step 4, image 1 of 2 HTC myTouch 3G Trackball Replacement: step 4, image 2 of 2
    • Remove the two Phillips head 3 mm screws located on the bottom circuit board.
    • Locate the small ribbon cable just below the serial number barcode. Use a safe removal tool or precision flathead to gently detach the cable.
  5. HTC myTouch 3G Trackball Replacement: step 5, image 1 of 2 HTC myTouch 3G Trackball Replacement: step 5, image 2 of 2
    • Lift up the circuit board gently from the right. You will notice some resistance due to the two ribbon cables attached underneath the circuit board. Continue to lift gently on the right until the ribbons detach and the resistance is released.
    • Proceed carefully with this step so that the cables are released without damage.
  6. HTC myTouch 3G Trackball Replacement: step 6, image 1 of 1
    • Flip the circuit board over to reveal the trackball.
    • If you want to clean the trackball, use an air duster and gently spray it. Keep a distance of 2-4 inches between the duster and trackball.
    • If you are not replacing the trackball, you may reassemble at this point. If you are replacing the trackball, skip the previous bullet and move on to Step 7.
  7. HTC myTouch 3G Trackball Replacement: step 7, image 1 of 2 HTC myTouch 3G Trackball Replacement: step 7, image 2 of 2
    • To remove the trackball, lay the circuit board face down and locate the two prongs as shown in the picture.
    • Use a precision flathead screwdriver to dislodge the prongs from the circuit board and push the prongs through the slots. The trackball should detach from the circuit board.
  8. HTC myTouch 3G Trackball Replacement: step 8, image 1 of 2 HTC myTouch 3G Trackball Replacement: step 8, image 2 of 2
    • Insert a new trackball by guiding the prongs through the slots on the circuit board.
    • Once the trackball is in place, gently press down to ensure the trackball is secure.
    • Verify the prongs are latched to the circuit board.
Erik
96 Reputation
2 Guides authored
Cal Poly, Team 2-9, Propen Fall 2012 Member of Cal Poly, Team 2-9, Propen Fall 2012
CPSU-PROPEN-F12S2G9
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 1,265
