HUAWEI HONOR 5X Front And Back Camera Replacement
Klara Asllani
Klara Asllani and one other contributor
Last updated on September 3, 2021
No estimate
Moderate
Introduction
Go to step 1
If the camera has been cracked or shows blurry pictures, it may need to be replaced.
Tools
Show more…
  1. HUAWEI HONOR 5X Front And Back Camera Replacement, HUAWEI HONOR 5X Disassembly: step 1, image 1 of 1
    • Turn off your cell phone before disassembling.
  2. HUAWEI HONOR 5X Front And Back Camera Replacement: step 2, image 1 of 1
    • Remove the two 1.17mm Torx T3 screws from the bottom of the phone.
  3. HUAWEI HONOR 5X Front And Back Camera Replacement: step 3, image 1 of 2 HUAWEI HONOR 5X Front And Back Camera Replacement: step 3, image 2 of 2
    • Use the Sim card ejection tool to remove both the sim card trays.
  4. HUAWEI HONOR 5X Front And Back Camera Replacement: step 4, image 1 of 1
    • To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
  5. HUAWEI HONOR 5X Front And Back Camera Replacement: step 5, image 1 of 2 HUAWEI HONOR 5X Front And Back Camera Replacement: step 5, image 2 of 2
    • Pry off the back with a plastic opening tool.
  6. HUAWEI HONOR 5X Front And Back Camera Replacement, Motherboard: step 6, image 1 of 2 HUAWEI HONOR 5X Front And Back Camera Replacement, Motherboard: step 6, image 2 of 2
    • Remove the five 1.5mm Phillips #000 screws from the motherboard.
  7. HUAWEI HONOR 5X Front And Back Camera Replacement: step 7, image 1 of 2 HUAWEI HONOR 5X Front And Back Camera Replacement: step 7, image 2 of 2
    Tool used on this step:
    • Use a plastic opening tool to pry up and disconnect the display cable from the motherboard.
    • Use tweezers to disconnect the white coax cable.
    • Use tweezers to disconnect the power and volume cable.
  8. HUAWEI HONOR 5X Front And Back Camera Replacement: step 8, image 1 of 3 HUAWEI HONOR 5X Front And Back Camera Replacement: step 8, image 2 of 3 HUAWEI HONOR 5X Front And Back Camera Replacement: step 8, image 3 of 3
    • Remove the motherboard.
  9. HUAWEI HONOR 5X Front And Back Camera Replacement, Front And Back Camera: step 9, image 1 of 1
    • Use a plastic opening tool to pry up and disconnect the camera from the motherboard.
  10. HUAWEI HONOR 5X Front And Back Camera Replacement: step 10, image 1 of 1
    • Use a plastic opening tool to pry the front camera connector from its socket on the motherboard.
Klara Asllani
788 Reputation
5 Guides authored
USF Tampa, Team S7-G6, Passmore Spring 2018 Member of USF Tampa, Team S7-G6, Passmore Spring 2018
USFT-PASSMORE-S18S7G6
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 394
