Hair Dryer Electrical Brushes Replacement
  1. Hair Dryer Electrical Brushes Replacement, Electrical Brushes: step 1, image 1 of 3 Hair Dryer Electrical Brushes Replacement, Electrical Brushes: step 1, image 2 of 3 Hair Dryer Electrical Brushes Replacement, Electrical Brushes: step 1, image 3 of 3
    • Make sure to unplug the device before beginning.
    • Rotate the stainless steel filter counterclockwise and pull upwards to remove it.
  2. Hair Dryer Electrical Brushes Replacement: step 2, image 1 of 2 Hair Dryer Electrical Brushes Replacement: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the two screws securing the back cover.
  3. Hair Dryer Electrical Brushes Replacement: step 3, image 1 of 3 Hair Dryer Electrical Brushes Replacement: step 3, image 2 of 3 Hair Dryer Electrical Brushes Replacement: step 3, image 3 of 3
    • Lift off the back cover.
  4. Hair Dryer Electrical Brushes Replacement: step 4, image 1 of 3 Hair Dryer Electrical Brushes Replacement: step 4, image 2 of 3 Hair Dryer Electrical Brushes Replacement: step 4, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the two screws securing the dryer motor.
    • Remove the motor from its plastic housing.
  5. Hair Dryer Electrical Brushes Replacement: step 5, image 1 of 3 Hair Dryer Electrical Brushes Replacement: step 5, image 2 of 3 Hair Dryer Electrical Brushes Replacement: step 5, image 3 of 3
    • Unscrew the small plastic cap on the side of the motor and lift out the spring.
    • Remove the carbon electrical brush.
    • Repeat for the cap on the other side of the motor.
  6. Hair Dryer Electrical Brushes Replacement: step 6, image 1 of 3 Hair Dryer Electrical Brushes Replacement: step 6, image 2 of 3 Hair Dryer Electrical Brushes Replacement: step 6, image 3 of 3
    • Install the new carbon brushes, and screw the caps back on.
    • Make sure the spring beneath the cap is properly positioned before tightening,
  7. Hair Dryer Electrical Brushes Replacement: step 7, image 1 of 3 Hair Dryer Electrical Brushes Replacement: step 7, image 2 of 3 Hair Dryer Electrical Brushes Replacement: step 7, image 3 of 3
    • Place the motor back into the housing.
    • Rotate the motor clockwise to screw it into place.
    • Refasten the two motor screws using a Phillips #1 screwdriver.
  8. Hair Dryer Electrical Brushes Replacement: step 8, image 1 of 3 Hair Dryer Electrical Brushes Replacement: step 8, image 2 of 3 Hair Dryer Electrical Brushes Replacement: step 8, image 3 of 3
    • Place the white wires coming off the motor back in the slots.
    • Place the diode in the slots.
  9. Hair Dryer Electrical Brushes Replacement: step 9, image 1 of 2 Hair Dryer Electrical Brushes Replacement: step 9, image 2 of 2
    • Set the power cord back in its slot.
  10. Hair Dryer Electrical Brushes Replacement: step 10, image 1 of 3 Hair Dryer Electrical Brushes Replacement: step 10, image 2 of 3 Hair Dryer Electrical Brushes Replacement: step 10, image 3 of 3
    • Reinstall the back cover.
  11. Hair Dryer Electrical Brushes Replacement: step 11, image 1 of 3 Hair Dryer Electrical Brushes Replacement: step 11, image 2 of 3 Hair Dryer Electrical Brushes Replacement: step 11, image 3 of 3
    • Place the two screws back in place and tighten them with a Phillips #1 screwdriver.
Enjoy your functional hair dryer!
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 48
All Time: 1,099
