Hamilton Beach 48464 Tubing Replacement
  1. Hamilton Beach 48464 Tubing Replacement, Filter Basket: step 1, image 1 of 2 Hamilton Beach 48464 Tubing Replacement, Filter Basket: step 1, image 2 of 2
    • Carefully open the top lid of the Brew Station.
  2. Hamilton Beach 48464 Tubing Replacement: step 2, image 1 of 1
    • Slide out the filter basket that is sitting on top after opening the lid.
  3. Hamilton Beach 48464 Tubing Replacement, Tubing: step 3, image 1 of 2 Hamilton Beach 48464 Tubing Replacement, Tubing: step 3, image 2 of 2
    • Using the Philips 2 Screwdriver, unscrew the two 8-mm screws labeled in a red outline.
    • Once screws are removed, pull off the little circle piece.
  4. Hamilton Beach 48464 Tubing Replacement: step 4, image 1 of 2 Hamilton Beach 48464 Tubing Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, grab the tube that is exposed after you pulled the piece off in step 1 and pull it up and out of the Brew Station.
  5. Hamilton Beach 48464 Tubing Replacement: step 5, image 1 of 2 Hamilton Beach 48464 Tubing Replacement: step 5, image 2 of 2
    • Using the Philips 2 Screwdriver, unscrew the three 8-mm screws labeled in a red outline.
    • Once screws are removed, gently pull off the liner that is on the inside of the lid.
  6. Hamilton Beach 48464 Tubing Replacement: step 6, image 1 of 2 Hamilton Beach 48464 Tubing Replacement: step 6, image 2 of 2
    • After completing Step 3, you will be exposed to a little piece attached to the inside of the lid. Pull this piece out, as it is the last piece of tubing used in the Brew Station.
Michael Damico
661 Reputation
6 Guides authored
USF Tampa, Team 14-1, Lacy Spring 2016 Member of USF Tampa, Team 14-1, Lacy Spring 2016
USFT-LACY-S16S14G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 16
All Time: 806
