Hamilton Beach 51101BA Power Cord Replacement
  1. Hamilton Beach 51101BA Power Cord Replacement, Power Cord: step 1, image 1 of 3 Hamilton Beach 51101BA Power Cord Replacement, Power Cord: step 1, image 2 of 3 Hamilton Beach 51101BA Power Cord Replacement, Power Cord: step 1, image 3 of 3
    • Remove container from base.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  2. Hamilton Beach 51101BA Power Cord Replacement: step 2, image 1 of 1
    • Turn the blender so the bottom is facing you.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
  3. Hamilton Beach 51101BA Power Cord Replacement: step 3, image 1 of 1
    • Lift the two wires from the motor platform.
  4. Hamilton Beach 51101BA Power Cord Replacement: step 4, image 1 of 1
    • Using the wire cutters, cut the end of the thick black wires.
To reassemble your device, you must solder the new power cord to the thin black and thin gray wires, and follow the steps in reverse order. Requires soldering skills.
Andrew Huff
568 Reputation
3 Guides authored
USF Tampa, Team 2-5, Sullivan Fall 2015 Member of USF Tampa, Team 2-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 15
All Time: 1,997
