Hamilton Beach 51101BA Rotor Replacement
  1. Hamilton Beach 51101BA Rotor Replacement, Rotor: step 1, image 1 of 3 Hamilton Beach 51101BA Rotor Replacement, Rotor: step 1, image 2 of 3 Hamilton Beach 51101BA Rotor Replacement, Rotor: step 1, image 3 of 3
    • Remove the container from the blender.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  2. Hamilton Beach 51101BA Rotor Replacement: step 2, image 1 of 1
    • Turn the blender so the bottom is facing you.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
  3. Hamilton Beach 51101BA Rotor Replacement: step 3, image 1 of 1
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
  4. Hamilton Beach 51101BA Rotor Replacement: step 4, image 1 of 1
    • Unhinge the plastic motor platform from the blender.
    • You may need a plastic spudger to unhinge the motor platform from the blender.
  5. Hamilton Beach 51101BA Rotor Replacement: step 5, image 1 of 2 Hamilton Beach 51101BA Rotor Replacement: step 5, image 2 of 2
    • Using a spudger, carefully insert the tip into the coil of wire around motor.
    • This is used to hold the rotating piece of the motor still.
  6. Hamilton Beach 51101BA Rotor Replacement: step 6, image 1 of 1
    • Remove the white rotor piece by rotating it counter-clockwise.
    • While rotating, make sure the rotating piece of the motor remains still.
Andrew Huff
568 Reputation
3 Guides authored
USF Tampa, Team 2-5, Sullivan Fall 2015 Member of USF Tampa, Team 2-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G5
4 Members
5 Guides authored
One Comment
Hi, Any idea where to get a new rotor.
Allen Reed - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 1,294
