Hamilton Beach 62683 Disassembly
  1. Hamilton Beach 62683 Disassembly, Hamilton Beach 62683: step 1, image 1 of 1
    • Hold the hand-mixer upside down in order to access the bottom.
    • Remove the three screws using a Phillips #00 screwdriver.
    • Carefully remove the bottom of the plastic casing.
  2. Hamilton Beach 62683 Disassembly: step 2, image 1 of 3 Hamilton Beach 62683 Disassembly: step 2, image 2 of 3 Hamilton Beach 62683 Disassembly: step 2, image 3 of 3
    • Remove the nine screws using a Phillips #00 screwdriver.
    • The two top most screws will be the most challenging to remove; consider using a longer Phillips screwdriver in order to reach them.
    • Flip the mixer right side up to remove the top plastic shell.
  3. Hamilton Beach 62683 Disassembly: step 3, image 1 of 2 Hamilton Beach 62683 Disassembly: step 3, image 2 of 2
    • Using light force, remove the black micro switch from the plastic shell.
    • Press the multi switch dial down, being careful to hold on to the mechanism as this will remove it entirely from the plastic shell.
Attached Documents
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 64
All Time: 398
