Hamilton Beach 70740 Base Replacement
  1. Hamilton Beach 70740 Base Replacement, Bowl and Lid: step 1, image 1 of 2 Hamilton Beach 70740 Base Replacement, Bowl and Lid: step 1, image 2 of 2
    • Turn the bowl counterclockwise and lift.
  2. Hamilton Beach 70740 Base Replacement, Base: step 2, image 1 of 2 Hamilton Beach 70740 Base Replacement, Base: step 2, image 2 of 2
    • Using a #2 Phillips head screwdriver, remove the two 11 mm screws from the base.
    • Pull suction cups straight out.
  3. Hamilton Beach 70740 Base Replacement: step 3, image 1 of 3 Hamilton Beach 70740 Base Replacement: step 3, image 2 of 3 Hamilton Beach 70740 Base Replacement: step 3, image 3 of 3
    Tool used on this step:
    Heavy-Duty Spudger
    Buy
    • Remove rubber caps using the heavy duty spudger.
    • Remove the four 11 mm screws using the #2 Phillips head screwdriver.
    • Pull base straight out.
Travis Williams
552 Reputation
5 Guides authored
USF Tampa, Team 17-4, Blackwell Spring 2017 Member of USF Tampa, Team 17-4, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G4
3 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 358
