Hamilton Beach 70740 Internal switch Replacement
  1. Hamilton Beach 70740 Internal switch Replacement, Bowl and Lid: step 1, image 1 of 2 Hamilton Beach 70740 Internal switch Replacement, Bowl and Lid: step 1, image 2 of 2
    • Turn the bowl counterclockwise and lift.
  2. Hamilton Beach 70740 Internal switch Replacement, Power Knob: step 2, image 1 of 3 Hamilton Beach 70740 Internal switch Replacement, Power Knob: step 2, image 2 of 3 Hamilton Beach 70740 Internal switch Replacement, Power Knob: step 2, image 3 of 3
    Tool used on this step:
    Heavy-Duty Spudger
    Buy
  3. Hamilton Beach 70740 Internal switch Replacement, Base: step 3, image 1 of 2 Hamilton Beach 70740 Internal switch Replacement, Base: step 3, image 2 of 2
    • Using a #2 Phillips head screwdriver, remove the two 11 mm screws from the base.
    • Pull suction cups straight out.
  4. Hamilton Beach 70740 Internal switch Replacement: step 4, image 1 of 3 Hamilton Beach 70740 Internal switch Replacement: step 4, image 2 of 3 Hamilton Beach 70740 Internal switch Replacement: step 4, image 3 of 3
    Heavy-Duty Spudger
    Buy
    • Remove rubber caps using the heavy duty spudger.
    • Remove the four 11 mm screws using the #2 Phillips head screwdriver.
    • Pull base straight out.
  5. Hamilton Beach 70740 Internal switch Replacement, Internal switch: step 5, image 1 of 2 Hamilton Beach 70740 Internal switch Replacement, Internal switch: step 5, image 2 of 2
    • Remove the two 11 mm screws using the #2 Phillips head screwdriver.
  6. Hamilton Beach 70740 Internal switch Replacement: step 6, image 1 of 2 Hamilton Beach 70740 Internal switch Replacement: step 6, image 2 of 2
    • Cut all four red wires using the wire stripper crimping tool.
    • Using the wire stripper crimping tool strip the ends of each red wire and insert them into a new wiring connector cap, then crimp firmly.
    • Cut the white wire using the stripper crimping tool.
    • Using the wire stripper crimping tool strip the ends of each of the white wires and insert them into the opposite ends of a parallel connector, then crimp firmly.
Travis Williams
552 Reputation
5 Guides authored
USF Tampa, Team 17-4, Blackwell Spring 2017 Member of USF Tampa, Team 17-4, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G4
3 Members
7 Guides authored
2 Guide Comments
On our unit the control knob became stuck. Where can I get a new control knob? Do you happen to know the part number?
Mitchell Arends - Reply Share
I used a hair dryer and that did the trick, but am wondering if WD 40 would work as well. I went online e with the company and they want $2.00 for tech advice which is dumb to me. At first I thought it was the locking device on top; it is actually the pulse switch and my machine is just over a year old.
joanneferrato - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 31
All Time: 1,186
