Introduction
This guide is used to replace the motor.
Step 1 Base Removal
Careful: steps 1-5 are sourced from a guide that's marked as in-progress.
Hold the food processor upside down and remove the two screws indicated with a screwdriver. Once unscrewed, remove the two rubber suction pads.
Use a regular nylon spudger to remove the plastic caps at these locations with moderate pressure.
Remove to electrical cap to the positive terminal(black terminal), and undo the wiring.
2 other people completed this guide.
