Hamilton Beach Food Processor 70740 Motor/Cord Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Careful: steps 1-5 are sourced from a guide that's marked as in-progress.
    Hamilton Beach Food Processor 70740 Motor/Cord Replacement, Base Removal: step 1, image 1 of 3 Hamilton Beach Food Processor 70740 Motor/Cord Replacement, Base Removal: step 1, image 2 of 3 Hamilton Beach Food Processor 70740 Motor/Cord Replacement, Base Removal: step 1, image 3 of 3
    • Hold the food processor upside down and remove the two screws indicated with a screwdriver. Once unscrewed, remove the two rubber suction pads.
  2. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: step 2, image 1 of 2 Hamilton Beach Food Processor 70740 Motor/Cord Replacement: step 2, image 2 of 2
    • Use a spudger to remove the 4 rubber base pads located at the corners of the device.
  3. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: step 3, image 1 of 1
    • Unscrew all 4 screws that are located beneath the pads with a screwdriver and remove the plastic grey base.
  4. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: step 4, image 1 of 1
    • Remove the screws indicated with a screw driver.
  5. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: step 5, image 1 of 1
    • Remove the two screws behind the knob with a screwdriver.
  6. Hamilton Beach Food Processor 70740 Motor/Cord Replacement, Motor/Cord: step 6, image 1 of 1
    • Use a regular nylon spudger to remove the plastic caps at these locations with moderate pressure.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Apply pressure at the edge of the plastic cap circles. Apply stress elsewhere may damage the device.
    • Note that the plastic caps are glued
  7. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: step 7, image 1 of 1
    • Remove the 4 screws located under the plastic caps with a screw driver.
  8. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: step 8, image 1 of 2 Hamilton Beach Food Processor 70740 Motor/Cord Replacement: step 8, image 2 of 2
    • Lift and remove the plastic gears at the center of the device.
    • Remove any grease residue underneath the plastic gears.
  9. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: step 9, image 1 of 2 Hamilton Beach Food Processor 70740 Motor/Cord Replacement: step 9, image 2 of 2
    • Remove the remaining screws to unhinge the motor located at the center of the device using a screw driver.
David Gedeon
806 Reputation
6 Guides authored
IUPUI, Team 1-1, Baechle Fall 2015 Member of IUPUI, Team 1-1, Baechle Fall 2015
IUPUI-BAECHLE-F15S1G1
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 222
