Hamilton C2 Air Inlet Filter Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Hamilton C2 Air Inlet Filter Replacement, shut down the ventilator: step 1, image 1 of 2 Hamilton C2 Air Inlet Filter Replacement, shut down the ventilator: step 1, image 2 of 2
    • Press and quickly release the power switch to open standby window in the screen.
    • Activate the standby mode by pressing the Active standby button in the screen.
    • Press and hold the switch for greater than 3 seconds to shut down the ventilator.
    • If there is a technical fault, press and hold the switch for greater than 10 seconds.
    • Disconnect the ventilator from the AC or DC power.
  2. Hamilton C2 Air Inlet Filter Replacement, remove filter cover panel: step 3, image 1 of 1
    • The filter cover panel is attached with 2 latches.
    • Detach top latches, swivel away from the rear and remove the cover panel.
  3. Hamilton C2 Air Inlet Filter Replacement, replace filters: step 4, image 1 of 2 Hamilton C2 Air Inlet Filter Replacement, replace filters: step 4, image 2 of 2
    • Remove dust filters.
    • Raise the HEPA Filter Latch.
    • Use the handle to pull the HEPA Filter from the holder and replace as required.
    • Install new dust filters or wash the existing filter in a mild soap solution, rinse, dry and reinstall.
  1. Place back the cover panel
  2. Connect the ventilator back to the AC or DC power.
  3. Power on the ventilator with the power switch.
  4. Run the preoperational check.
knipwim
14,774 Reputation
42 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 680
