Hamilton G5 Expiratory Valve Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Hamilton G5 Expiratory Valve Replacement, Rail: step 1, image 1 of 1
    • Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
  2. Hamilton G5 Expiratory Valve Replacement: step 2, image 1 of 1
    • Remove the Rail (B).
  3. Hamilton G5 Expiratory Valve Replacement: step 3, image 1 of 1
    • The Standoff Brackets (C) remain with the Main Cover.
    • Place aside in a safe location.
  4. Hamilton G5 Expiratory Valve Replacement, Main Cover: step 5, image 1 of 1
    • Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
  5. Hamilton G5 Expiratory Valve Replacement, Expiratory Valve: step 7, image 1 of 1
    • Disconnect 2 cables from the magnet of the Expiratory Valve.
  6. Hamilton G5 Expiratory Valve Replacement: step 8, image 1 of 1
    • Remove the Expiratory Valve Cover (A) and Silicon Membrane (A) (if not already removed).
  7. Hamilton G5 Expiratory Valve Replacement: step 9, image 1 of 1
    • Remove 3 Hex Allen screws (B) M3x8
  8. Hamilton G5 Expiratory Valve Replacement: step 10, image 1 of 1
    • Remove the Expiratory Valve.
Sierra Saenz
366 Reputation
3 Guides authored
Cal Poly, Team S7-G25, Paton Spring 2020 Member of Cal Poly, Team S7-G25, Paton Spring 2020
CPSU-PATON-S20S7G25
6 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 627
