Hamilton G5 Inspiratory Valve Replacement
William
William and 2 other contributors
Last updated on July 3, 2020
15 minutes
Moderate
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Introduction
Go to step 1
For more information on replacing the inspiratory valve, please refer to section 10 in the service manual.
iFixit earns commission when you buy through these links.
  1. Hamilton G5 Inspiratory Valve Replacement, Rail: step 1, image 1 of 1
    • Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
  2. Hamilton G5 Inspiratory Valve Replacement: step 2, image 1 of 1
    • Remove the Rail (B).
  3. Hamilton G5 Inspiratory Valve Replacement: step 3, image 1 of 1
    • The Standoff Brackets (C) remain with the Main Cover.
    • Place aside in a safe location.
  4. Hamilton G5 Inspiratory Valve Replacement, Main Cover: step 5, image 1 of 1
    • Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
  5. Hamilton G5 Inspiratory Valve Replacement, Safety Valve Block: step 7, image 1 of 1
    • Remove Safety Valve Block
    • 1. Disconnect the cable from the Ambient Valve Solenoid
    • 2. Disconnect the Shaped Hose (A)
    • 3. Remove the 2 Hex Allen Screws (B)
    • 4. Remove the Safety Valve Block
    • To remove Ambient Valve Solenoid: Unscrew the Ambient Valve Solenoid (C) form the Safety Valve Block
  6. Hamilton G5 Inspiratory Valve Replacement, Inspiratory Valve: step 8, image 1 of 2 Hamilton G5 Inspiratory Valve Replacement, Inspiratory Valve: step 8, image 2 of 2
    • Removing the Inspiration Valve
    • 1. Disconnect the tubing and cables form the Inspiration Valve
    • 3. Remove 2 Hex Allen screws (B) M5x60
    • 4. Move the Inspiration Valve forward and then up
    • 5. Remove the Inspiration Valve
William
145 Reputation
2 Guides authored
Cal Poly, Team S7-G25, Paton Spring 2020 Member of Cal Poly, Team S7-G25, Paton Spring 2020
CPSU-PATON-S20S7G25
6 Members
11 Guides authored
One Comment
wow great manual! very helpful and informative!
William - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 290
