Hamilton G5 Interactive Panel Motherboard Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Hamilton G5 Interactive Panel Motherboard Replacement, Hamilton G5 Rear Panel-Metal Shield Disassembly: step 1, image 1 of 1
    • Remove the screw (A) and washer(B) and remove the cable management cover (C).
  2. Hamilton G5 Interactive Panel Motherboard Replacement: step 2, image 1 of 1
    • Remove the 4 screws (D) to remove the panel's swivel mount (E).
  3. Hamilton G5 Interactive Panel Motherboard Replacement: step 3, image 1 of 1
    • Remove the 6 screws (F) and remove the back panel (G).
  4. Hamilton G5 Interactive Panel Motherboard Replacement: step 4, image 1 of 1
    • Remove the 5 screws and remove the metal shield.
  5. Hamilton G5 Interactive Panel Motherboard Replacement, Interactive Panel Motherboard: step 5, image 1 of 1
    • Insert wisdom here.
  6. Hamilton G5 Interactive Panel Motherboard Replacement: step 6, image 1 of 1
    • Disconnect all cables from the motherboard.
  7. Hamilton G5 Interactive Panel Motherboard Replacement: step 7, image 1 of 1
    • If nessesary, remove the ESM module by disconnecting the module from the connecting sockets (A).
  8. Hamilton G5 Interactive Panel Motherboard Replacement: step 8, image 1 of 1
    • Remove the 3 screws and 3 nuts, then lift out the motherboard.
Dane Dormedy
349 Reputation
3 Guides authored
Cal Poly, Team S7-G25, Paton Spring 2020 Member of Cal Poly, Team S7-G25, Paton Spring 2020
CPSU-PATON-S20S7G25
6 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 207
