Hamilton G5 Nebulizer Valve Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Hamilton G5 Nebulizer Valve Replacement, Rail: step 1, image 1 of 1
    • Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
  2. Hamilton G5 Nebulizer Valve Replacement: step 2, image 1 of 1
    • Remove the Rail (B).
  3. Hamilton G5 Nebulizer Valve Replacement: step 3, image 1 of 1
    • The Standoff Brackets (C) remain with the Main Cover.
    • Place aside in a safe location.
  4. Hamilton G5 Nebulizer Valve Replacement, Main Cover: step 5, image 1 of 1
    • Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
  5. Hamilton G5 Nebulizer Valve Replacement, Nebulizer Valve: step 7, image 1 of 1
    • After the rail and main cover are taken off, remove the dark blue tubing connected to the nebulizer, pictured here.
  6. Hamilton G5 Nebulizer Valve Replacement: step 8, image 1 of 1
    • Remove the two phillips screws labeled A from the Nebulizer valve.
  7. Hamilton G5 Nebulizer Valve Replacement: step 9, image 1 of 1
    • Remove the nebulizer valve parts.
    • The Nebulizer Valve parts are:B. Straight fitting
    • C. Front Nozzle fitting
    • D. Elbow fitting
    • E. Mounting bracket
    • F. Hex Allen screw for attaching the bracket to the Safety Valve Block
Cole Korchek
133 Reputation
1 Guide authored
Cal Poly, Team S7-G25, Paton Spring 2020 Member of Cal Poly, Team S7-G25, Paton Spring 2020
CPSU-PATON-S20S7G25
6 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 342
