Hamilton G5 Ventilation Unit Motherboard Replacement
Dane Dormedy
Dane Dormedy and one other contributor
Last updated on July 3, 2020
10 minutes
Easy
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Introduction
Go to step 1
For more information on replacing the motherboard, please refer to section 10 in the service manual.
iFixit earns commission when you buy through these links.
  1. Hamilton G5 Ventilation Unit Motherboard Replacement, Rail: step 1, image 1 of 1
    • Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
  2. Hamilton G5 Ventilation Unit Motherboard Replacement: step 2, image 1 of 1
    • Remove the Rail (B).
  3. Hamilton G5 Ventilation Unit Motherboard Replacement: step 3, image 1 of 1
    • The Standoff Brackets (C) remain with the Main Cover.
    • Place aside in a safe location.
  4. Hamilton G5 Ventilation Unit Motherboard Replacement, Main Cover: step 5, image 1 of 1
    • Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
  5. Hamilton G5 Ventilation Unit Motherboard Replacement, Ventilation Unit Motherboard: step 7, image 1 of 1
    • First, we need to remove the ESM module. It is connected to 2 connector sockets. Disconnect and remove.
    • Take out the Ventilation Real-time Controller (VRC) SW chip
  6. Hamilton G5 Ventilation Unit Motherboard Replacement: step 9, image 1 of 1
    • Install the ESM Module, by connecting the connectors (A), and the VRC SW chip on the new board.
  7. Hamilton G5 Ventilation Unit Motherboard Replacement: step 10, image 1 of 1
    • Disconnect all cables and connections from the board to the unit.
  8. Hamilton G5 Ventilation Unit Motherboard Replacement: step 11, image 1 of 1
    • Remove the three Hex screws (B).
  9. Hamilton G5 Ventilation Unit Motherboard Replacement: step 12, image 1 of 1
    • Move the motherboard out then up away from the ventilation unit (C).
Dane Dormedy
349 Reputation
3 Guides authored
Cal Poly, Team S7-G25, Paton Spring 2020 Member of Cal Poly, Team S7-G25, Paton Spring 2020
CPSU-PATON-S20S7G25
6 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 308
