Hamilton-T1 Oxygen Cells Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Hamilton-T1 Oxygen Cells Replacement, Oxygen Cells: step 1, image 1 of 1
    • Flip device around until the back panel is exposed.
  2. Hamilton-T1 Oxygen Cells Replacement: step 2, image 1 of 1
    • Remove the screw in the bottom center of the panel, and then take the panel off.
  3. Hamilton-T1 Oxygen Cells Replacement: step 3, image 1 of 1
    • Disconnect the oxygen cell by removing the tube.
    • Then twist the cell counter-clockwise and pull to remove the oxygen cell.
    • Install the new oxygen cell and put the back cover on.
    • After the cell is installed. Run the oxygen cell calibration.
    • Oxygen calibration guide can be found in 3-11 of the Hamilton-T1 operations manual.
After the installation and calibration of the oxygen cell. The Hamilton-T1 Ventilator is ready to operate.
Attached Documents
Tyler
114 Reputation
1 Guide authored
Cal Poly, Team S11-G24, Paton Spring 2020 Member of Cal Poly, Team S11-G24, Paton Spring 2020
CPSU-PATON-S20S11G24
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 39
All Time: 2,383
