Hand-Held Blender Motor Replacement
  1. Hand-Held Blender Motor Replacement, Motor: step 1, image 1 of 1
    • Place the product on a clean and empty surface.
  2. Hand-Held Blender Motor Replacement: step 2, image 1 of 1
    • Twist the attachment with the blades from the base of the blender.
  3. Hand-Held Blender Motor Replacement: step 3, image 1 of 1
    • Unscrew the Tri-point screw (2mm) on the top to disassemble the top part of the casing.
  4. Hand-Held Blender Motor Replacement: step 4, image 1 of 1
    • Unscrew the Phillips (2mm) connecting the middle part of the casing with the bottom part.
  5. Hand-Held Blender Motor Replacement: step 5, image 1 of 1
    • Use force to twist the middle part from the bottom part of the casing OR use spudgers to wiggle open the product.
    • This reveals the motor.
  6. Hand-Held Blender Motor Replacement: step 6, image 1 of 1
    • Lift the motor out of the casing.
    • Unscrew the Phillips (2mm) to disconnect the motor from the plastic part that transfers the motor rotations to the blade.
  7. Hand-Held Blender Motor Replacement: step 7, image 1 of 1
    • With a soldering iron disconnect the wires coming from the motor from the PCB.
    • Refer to this How to Solder and Desolder Connections guide to find more information on proper soldering techniques.
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 63
All Time: 3,510
