Handset Microphone Replacement
  1. Handset Microphone Replacement, Handset: step 1, image 1 of 1
    • After removing the BP-T18 battery pack, you will see two 11mm Phillips #0 screws located at the bottom of the phone. Remove both screws with a screwdriver.
    • Product is made of brittle plastic.
  2. Handset Microphone Replacement: step 2, image 1 of 2 Handset Microphone Replacement: step 2, image 2 of 2
    • Locate an easy point of access for a spudger, and then slowly insert it into the gap and pry it open.
    • The opening should become bigger if you exert force at a 30 degrees angle.
    • Increase the degree of slant until the back cover is completely removed.
  3. Handset Microphone Replacement: step 3, image 1 of 2 Handset Microphone Replacement: step 3, image 2 of 2
    • After removing the back cover, you will see 3 screws: one 7mm Phillips #0 screw at the top and two 11mm Phillips #0 screws at the bottom.
    • Use a screwdriver to remove all 3 screws.
  4. Handset Microphone Replacement, Handset Microphone: step 4, image 1 of 2 Handset Microphone Replacement, Handset Microphone: step 4, image 2 of 2
    • After disassembling the handset, you will see the inner components of the handset.
    • Locate the rubber part towards the very bottom of the handset. This is the microphone with protective rubber cover.
    • Remove the protective rubber cover. This may require a spudger.
    • The microphone is exposed upon removal of the protective rubber cover. Avoid contact with water.
2 other people completed this guide.
Han Shih
376 Reputation
4 Guides authored
IUPUI, Team 3-3, Harley Fall 2016 Member of IUPUI, Team 3-3, Harley Fall 2016
IUPUI-HARLEY-F16S3G3
4 Members
17 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 442
