Hard Drive Replacement Guide
  1. Hard Drive Replacement Guide, Hard Drive: step 1, image 1 of 1
    • Use a Phillips #0 screwdriver to loosen the screws.
    • The screws are designed to remain in the panel.
  2. Hard Drive Replacement Guide: step 2, image 1 of 3 Hard Drive Replacement Guide: step 2, image 2 of 3 Hard Drive Replacement Guide: step 2, image 3 of 3
    • To open the panel, use a plastic opening tool or your finger.
    • If there is difficulty opening the panel, than the screws may not be lose enough.
  3. Hard Drive Replacement Guide: step 3, image 1 of 2 Hard Drive Replacement Guide: step 3, image 2 of 2
    • Use the Phillips #0 screwdriver to unscrew the two 5mm screws.
    • Remove the hard drive by using your fingers to pull firmly on the clear tab.
  4. Hard Drive Replacement Guide: step 4, image 1 of 1
    • You have successfully removed the hard drive from the laptop.
Steven Park
420 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 869
