Harman Kardon Invoke Power Port Replacement
  1. Harman Kardon Invoke Power Port Replacement, Power Port: step 1, image 1 of 2 Harman Kardon Invoke Power Port Replacement, Power Port: step 1, image 2 of 2
    • Use a metal spudger to remove the rubber base.
  2. Harman Kardon Invoke Power Port Replacement: step 2, image 1 of 2 Harman Kardon Invoke Power Port Replacement: step 2, image 2 of 2
    • Use a T10 Torx screwdriver to remove the four 14 mm screws.
  3. Harman Kardon Invoke Power Port Replacement: step 3, image 1 of 2 Harman Kardon Invoke Power Port Replacement: step 3, image 2 of 2
    • Grip the bottom firmly and wiggle upwards to remove it.
  4. Harman Kardon Invoke Power Port Replacement: step 4, image 1 of 3 Harman Kardon Invoke Power Port Replacement: step 4, image 2 of 3 Harman Kardon Invoke Power Port Replacement: step 4, image 3 of 3
    • Use a T10 Torx screwdriver to remove two 10 mm screws from the board that is attached to the ports.
    • Pull the board up lightly.
  5. Harman Kardon Invoke Power Port Replacement: step 5, image 1 of 2 Harman Kardon Invoke Power Port Replacement: step 5, image 2 of 2
    • Pull the cable to disconnect the board from the device.
    • To replacement the service port, you will have to replace the whole board that the port is attached to.
One Comment
can I buy that power port circuit board from HK direct?
crokeclan - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 509
