Harman Kardon Invoke Service Port Replacement
  1. Harman Kardon Invoke Service Port Replacement, Remove the rubber base: step 1, image 1 of 2 Harman Kardon Invoke Service Port Replacement, Remove the rubber base: step 1, image 2 of 2
    • Use a metal spudger to remove the rubber bottom.
  2. Harman Kardon Invoke Service Port Replacement, Remove the base screws: step 2, image 1 of 2 Harman Kardon Invoke Service Port Replacement, Remove the base screws: step 2, image 2 of 2
    • Use a #10 Torx screwdriver to remove four 14 mm screws.
  3. Harman Kardon Invoke Service Port Replacement, Remove the base: step 3, image 1 of 2 Harman Kardon Invoke Service Port Replacement, Remove the base: step 3, image 2 of 2
    • Firmly grip the bottom and wiggle upwards to remove the base.
  4. Harman Kardon Invoke Service Port Replacement, Removing the board: step 4, image 1 of 3 Harman Kardon Invoke Service Port Replacement, Removing the board: step 4, image 2 of 3 Harman Kardon Invoke Service Port Replacement, Removing the board: step 4, image 3 of 3
    • Use a #10 Torx screwdriver to remove two 10 mm screws from board attached to ports.
    • Pull board up lightly.
  5. Harman Kardon Invoke Service Port Replacement, Disconnect the board: step 5, image 1 of 2 Harman Kardon Invoke Service Port Replacement, Disconnect the board: step 5, image 2 of 2
    • Pull cable to disconnect board from device.
    • For replacement of service port, you will have to replace whole board that the port is attached to.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 1,026
