Harman Kardon Invoke Speaker Replacement
  1. Harman Kardon Invoke Speaker Replacement, Speakers: step 1, image 1 of 3 Harman Kardon Invoke Speaker Replacement, Speakers: step 1, image 2 of 3 Harman Kardon Invoke Speaker Replacement, Speakers: step 1, image 3 of 3
    • Use metal spudger to remove top cover from smart speaker.
    • Use the Phillips #2 screwdriver, remove the three 17mm screws.
  2. Harman Kardon Invoke Speaker Replacement: step 2, image 1 of 3 Harman Kardon Invoke Speaker Replacement: step 2, image 2 of 3 Harman Kardon Invoke Speaker Replacement: step 2, image 3 of 3
    • Once the 17 mm screws are removed, lift the volume wheel.
    • Lift slowly as you do not want to damage the cable connected to the LED board.
    • Pull lightly on the cable in order to remove both the volume wheel and LED board.
  3. Harman Kardon Invoke Speaker Replacement: step 3, image 1 of 3 Harman Kardon Invoke Speaker Replacement: step 3, image 2 of 3 Harman Kardon Invoke Speaker Replacement: step 3, image 3 of 3
    • Use the Torx #10 screwdriver, remove the four 14 mm screws around the lid.
    • Remove lid.
  4. Harman Kardon Invoke Speaker Replacement: step 4, image 1 of 3 Harman Kardon Invoke Speaker Replacement: step 4, image 2 of 3 Harman Kardon Invoke Speaker Replacement: step 4, image 3 of 3
    • Once lid is removed, housing can now slide upwards.
    • Use the Torx #10 screwdriver, remove both 10 mm screws for each speaker that must be replaced.
  5. Harman Kardon Invoke Speaker Replacement: step 5, image 1 of 1
    • Pull on the speaker cables lightly in order to detach the speakers.
2 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 15
All Time: 1,275
