Harman Kardon Onyx Studio 2 Circuit Board Replacement
  1. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: step 1, image 1 of 3 Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: step 1, image 2 of 3 Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: step 1, image 3 of 3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Circuit Board Replacement: step 2, image 1 of 2 Harman Kardon Onyx Studio 2 Circuit Board Replacement: step 2, image 2 of 2
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Circuit Board Replacement: step 3, image 1 of 1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Circuit Board Replacement: step 4, image 1 of 2 Harman Kardon Onyx Studio 2 Circuit Board Replacement: step 4, image 2 of 2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
  5. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Control Board: step 5, image 1 of 1
    • Pull the silicone button band off of the outer edge of the speaker.
  6. Harman Kardon Onyx Studio 2 Circuit Board Replacement: step 6, image 1 of 2 Harman Kardon Onyx Studio 2 Circuit Board Replacement: step 6, image 2 of 2
    • Disconnect the two pressure connections from the circuit board.
  7. Harman Kardon Onyx Studio 2 Circuit Board Replacement: step 7, image 1 of 2 Harman Kardon Onyx Studio 2 Circuit Board Replacement: step 7, image 2 of 2
    • Gently remove the control board band by placing fingers in contact with it through the button openings.
    • Work from the outer edges in so as not to bend the band.
  8. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Circuit Board: step 8, image 1 of 2 Harman Kardon Onyx Studio 2 Circuit Board Replacement, Circuit Board: step 8, image 2 of 2
    • Disconnect the remaining connectors from the circuit board.
    • Disconnect the Bluetooth antenna.
  9. Harman Kardon Onyx Studio 2 Circuit Board Replacement: step 9, image 1 of 2 Harman Kardon Onyx Studio 2 Circuit Board Replacement: step 9, image 2 of 2
    • Remove the four 10 mm T10 Torx screws.
    • Pull the circuit board out of the device as it is now free.
11 other people completed this guide.
Alexandra Achtenberg
2,051 Reputation
6 Guides authored
USF Tampa, Team 16-5, Blackwell Spring 2017 Member of USF Tampa, Team 16-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G5
3 Members
24 Guides authored
5 Comments
Where do I get another one
Adrian tlahuel - Reply
Where we buy the board?
Eric Therrien - Reply
Umm… this was rather anticlimactic. Last step was basically like “and now contemplate your life choices”.
markcendan - Reply
Where can I Buy a new hk onix studio Main board?
tecnologia en localizaciòn - Reply
My speaker was working great. I just disconnected my phone to make a call, put YouTube back on it was all mumbled & the big button in the back kept pulsing so fast.
Maureen Field - Reply
Past 24 Hours: 1
Past 7 Days: 29
Past 30 Days: 144
All Time: 21,867
