Harman Kardon Onyx Studio 2 Front Panel Replacement
  1. Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: step 1, image 1 of 3 Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: step 1, image 2 of 3 Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: step 1, image 3 of 3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Front Panel Replacement: step 2, image 1 of 2 Harman Kardon Onyx Studio 2 Front Panel Replacement: step 2, image 2 of 2
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Front Panel Replacement: step 3, image 1 of 1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Front Panel Replacement: step 4, image 1 of 2 Harman Kardon Onyx Studio 2 Front Panel Replacement: step 4, image 2 of 2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
To reassemble, follow these steps in reverse order.
2 other people completed this guide.
Alexandra Achtenberg
2,051 Reputation
6 Guides authored
USF Tampa, Team 16-5, Blackwell Spring 2017 Member of USF Tampa, Team 16-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G5
3 Members
24 Guides authored
One Comment
Hi, I have the ONYX STUDIO with the silver ring that serves as the stand and the handle at the same time. After removing the front grill, I find the same five holes as it is shown on your pics but there are no screws. I can just see a bottom made of plastic. Do you have experience with that? Is that just some cover I can get thru using a screwdriver and I find the screws beneath?
I want to look inside as I am facing the problem with not working battery. As soon as I unplug the power source, it stops working.
Thank you for your comments.
Vaclav Matoulek - Reply
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 40
All Time: 6,155
