Harman Kardon Onyx Studio 2 Speakers Replacement
Alexandra Achtenberg
Alexandra Achtenberg and one other contributor
Last updated on July 2, 2020
25 - 35 minutes
Moderate
Introduction
Go to step 1
If your speakers are busted or faulty, this guide will help you in replacing one or both of the speakers in your Onyx Studio 2.
Tools
Show more…
  1. Harman Kardon Onyx Studio 2 Speakers Replacement, Front Panel: step 1, image 1 of 3 Harman Kardon Onyx Studio 2 Speakers Replacement, Front Panel: step 1, image 2 of 3 Harman Kardon Onyx Studio 2 Speakers Replacement, Front Panel: step 1, image 3 of 3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
    Where can I find a new front panel for my speaker
    consomme69 - Reply
    If I take this off can I put it back on
    Burger King - Reply
  2. Harman Kardon Onyx Studio 2 Speakers Replacement: step 2, image 1 of 2 Harman Kardon Onyx Studio 2 Speakers Replacement: step 2, image 2 of 2
    • Remove the five 14.4 mm T10 Torx screws.
    There are NO torxscrews. You have to pull out the rubber grille grips that are inside the screw holes FIRST, then use a regular sized Phillips head screwdriver to remove the cover. No Torxscrewdiver needed. I found this out after I had already purchased one from you guys.
    phillip columbus - Reply
    Mi bocina no tiene los 5 tornillos a la vista,tiene las cavidades ciegas, como lo abro???
    Eduardo Heine - Reply
    Yes there are no Torx screws… you have to remove the rubber grips them the Philip Screws..
    Joe Lim - Reply
  3. Harman Kardon Onyx Studio 2 Speakers Replacement: step 3, image 1 of 1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Speakers Replacement: step 4, image 1 of 2 Harman Kardon Onyx Studio 2 Speakers Replacement: step 4, image 2 of 2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
    Please can I get a replacement of my panel to the phone
    Chinedu Ogunedo - Reply
  5. Harman Kardon Onyx Studio 2 Speakers Replacement, Control Board: step 5, image 1 of 1
    • Pull the silicone button band off of the outer edge of the speaker.
  6. Harman Kardon Onyx Studio 2 Speakers Replacement: step 6, image 1 of 2 Harman Kardon Onyx Studio 2 Speakers Replacement: step 6, image 2 of 2
    • Disconnect the two pressure connections from the circuit board.
  7. Harman Kardon Onyx Studio 2 Speakers Replacement: step 7, image 1 of 2 Harman Kardon Onyx Studio 2 Speakers Replacement: step 7, image 2 of 2
    • Gently remove the control board band by placing fingers in contact with it through the button openings.
    • Work from the outer edges in so as not to bend the band.
    From where to buy Control panel
    ali - Reply
    From where to buy this control panel
    ali - Reply
    My speakers control board band broke. If possible, where can I find replacement?
    Abraham Lepez - Reply
  8. Harman Kardon Onyx Studio 2 Speakers Replacement, Circuit Board: step 8, image 1 of 2 Harman Kardon Onyx Studio 2 Speakers Replacement, Circuit Board: step 8, image 2 of 2
    • Disconnect the remaining connectors from the circuit board.
    • Disconnect the Bluetooth antenna.
  9. Harman Kardon Onyx Studio 2 Speakers Replacement: step 9, image 1 of 2 Harman Kardon Onyx Studio 2 Speakers Replacement: step 9, image 2 of 2
    • Remove the four 10 mm T10 Torx screws.
    • Pull the circuit board out of the device as it is now free.
    Bisa di kirim
    Mala Ganni - Reply
    Bisa pesan 1
    Mala Ganni - Reply
    I own two of these and the both shut down on their own.. where do I buy the replacement boards from?
    Darren Vincent - Reply
  10. Harman Kardon Onyx Studio 2 Speakers Replacement, Speakers: step 10, image 1 of 1
    • Using the metal spudger, gently pry off the two red and black connectors.
  11. Harman Kardon Onyx Studio 2 Speakers Replacement: step 11, image 1 of 2 Harman Kardon Onyx Studio 2 Speakers Replacement: step 11, image 2 of 2
    • Remove the four 14.3 mm T10 Torx screws.
  12. Harman Kardon Onyx Studio 2 Speakers Replacement: step 12, image 1 of 1
    • Pull out the speaker, and if necessary follow these steps to replace the other identical speaker.
    Please attach a link where best to buy parts/speakers for this model. I found your step by step instructions very well detailed except for the source of parts
    Bernard Rocha - Reply
7 other people completed this guide.
2,081 Reputation
6 Guides authored
USF Tampa, Team 16-5, Blackwell Spring 2017 Member of USF Tampa, Team 16-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G5
3 Members
24 Guides authored
2 Comments
Hi, do anyone know sparepart number for woofer elements?
Mikko Lehto - Reply
Hello.. what is the wattage of the speaker? and where can i get a replacement. how much?
James Santiago - Reply
Past 24 Hours: 5
Past 7 Days: 37
Past 30 Days: 117
All Time: 20,572
