Harrier Tablet by EE Disassembly
  1. Harrier Tablet by EE Disassembly, opening the first layer: step 1, image 1 of 3 Harrier Tablet by EE Disassembly, opening the first layer: step 1, image 2 of 3 Harrier Tablet by EE Disassembly, opening the first layer: step 1, image 3 of 3
    • Lay the tablet on a flat surface with the screen facing downward.
    • Use a guitar pick to pry up the rear most layer of the tablet, starting by the cover of the sim card.
    • Use a spudger to pry along the edges of the back layer of the tablet. Use the guitar picks to keep the edges propped open.
  2. Harrier Tablet by EE Disassembly, getting ready for the second layer: step 2, image 1 of 2 Harrier Tablet by EE Disassembly, getting ready for the second layer: step 2, image 2 of 2
    • Before opening the second layer, use a screwdriver to remove all the screws along the edges.
    • The top left screw has an anti-tamper seal on it. Damage to this seal will void any warranties of the tablet.
  3. Harrier Tablet by EE Disassembly, sort of disassemble entirely: step 3, image 1 of 2 Harrier Tablet by EE Disassembly, sort of disassemble entirely: step 3, image 2 of 2
    • Once the screws are removed, use a spudger and guitar picks to unclip the bezel.
    • Removing the battery and flexi rigid circuit board will likely cause damage. In order to disassemble further, you may also need to replace these parts.
    • To reassemble, first remove the sim card, then follow these instructions in reverse order.
    • Make sure the buttons are properly seated before snapping the first layer back on.
rarazzell
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 463
