Hasbro Bop-It Micro Series Levers Replacement
  1. Hasbro Bop-It Micro Series Levers Replacement, Back Case: step 1, image 1 of 1
    • Loosen the two captive 8 mm screws in the back cover using a Phillips #0 screwdriver.
  2. Hasbro Bop-It Micro Series Levers Replacement: step 2, image 1 of 1
    • Remove the six 6 mm screws from the back cover using a Phillips #0 screwdriver.
    • When removing the final screw, hold the assembly together. There is a spring inside the device which will pop the assembly apart when all the screws are removed.
  3. Hasbro Bop-It Micro Series Levers Replacement: step 3, image 1 of 1
    • Carefully separate the two sections, leaving them connected by the wires.
  4. Hasbro Bop-It Micro Series Levers Replacement, Levers: step 4, image 1 of 1
    • Observe the orientation of the levers before removal.
    • Remove the white plastic levers with your fingers.
2 other people completed this guide.
Glenn Haag
479 Reputation
3 Guides authored
IUPUI, Team 3-1, Harley Fall 2016 Member of IUPUI, Team 3-1, Harley Fall 2016
IUPUI-HARLEY-F16S3G1
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 33
All Time: 2,149
