Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement
  1. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: step 1, image 1 of 3 Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: step 1, image 2 of 3 Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: step 1, image 3 of 3
    • Find the removable panel at the bottom of the hand.
    • Use your finger to push upwards and open the panel.
    • Slide the panel off and separate it from the hand.
  2. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: step 2, image 1 of 2 Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: step 2, image 2 of 2
    • Remove the left-most battery by pushing down on the positive end and pulling it out.
    • Repeat this for the next two batteries.
  3. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, LED Lights: step 3, image 1 of 1
    • Remove the screws within the gauntlet and surrounding the palm.
  4. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: step 4, image 1 of 1
    • Open the gauntlet carefully, as there are wires connecting both sides.
    • Address which LED is faulty. Check if the wires connecting to it are all intact; If there is a detachment within the circuits, reconnect it to its location. The LED should operate in that instance.
  5. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: step 5, image 1 of 1
    • To replace the LED chip, remove the screw holding the chip in place.
  6. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: step 6, image 1 of 1
    • Ensure that the LED chip is in the correct area with the correct polarity.
    • Reconnect it to its respective surface and check if it fits with in the magnetic gem. If not, consider another replacement.
Jessica
109 Reputation
1 Guide authored
Marist, Team 1-3, Chaterdon Spring 2023 Member of Marist, Team 1-3, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G3
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 29
All Time: 222
