Hasee Z7M-i78172D1 Battery Replacement
  1. Hasee Z7M-i78172D1 Battery Replacement, Rear Panel: step 1, image 1 of 1
    • Use a #0 Phillips head screwdriver and unscrew the sixteen 7mm screws on the back of the device.
  2. Hasee Z7M-i78172D1 Battery Replacement: step 2, image 1 of 3 Hasee Z7M-i78172D1 Battery Replacement: step 2, image 2 of 3 Hasee Z7M-i78172D1 Battery Replacement: step 2, image 3 of 3
    • Use a plastic opening tool to take off the back plastic panel.
  3. Hasee Z7M-i78172D1 Battery Replacement, Battery: step 3, image 1 of 1
    • Use a Phillips #0 head screwdriver to remove the four 7mm screws that hold the battery in place.
  4. Hasee Z7M-i78172D1 Battery Replacement: step 4, image 1 of 2 Hasee Z7M-i78172D1 Battery Replacement: step 4, image 2 of 2
    • Gently pry off the connecting wires with the plastic opening tool.
  5. Hasee Z7M-i78172D1 Battery Replacement: step 5, image 1 of 2 Hasee Z7M-i78172D1 Battery Replacement: step 5, image 2 of 2
    • Lift the battery out.
Desiree Mora
289 Reputation
3 Guides authored
USF Tampa, Team S6-G6, Eyestone Spring 2018 Member of USF Tampa, Team S6-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S6G6
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 431
