Hasee Z7M-i78172D1 Graphic Card Fan Replacement
  1. Hasee Z7M-i78172D1 Graphic Card Fan Replacement, Rear Panel: step 1, image 1 of 1
    • Use a #0 Phillips head screwdriver and unscrew the sixteen 7mm screws on the back of the device.
  2. Hasee Z7M-i78172D1 Graphic Card Fan Replacement: step 2, image 1 of 3 Hasee Z7M-i78172D1 Graphic Card Fan Replacement: step 2, image 2 of 3 Hasee Z7M-i78172D1 Graphic Card Fan Replacement: step 2, image 3 of 3
    • Use a plastic opening tool to take off the back plastic panel.
  3. Hasee Z7M-i78172D1 Graphic Card Fan Replacement, Graphic Card Fan: step 3, image 1 of 3 Hasee Z7M-i78172D1 Graphic Card Fan Replacement, Graphic Card Fan: step 3, image 2 of 3 Hasee Z7M-i78172D1 Graphic Card Fan Replacement, Graphic Card Fan: step 3, image 3 of 3
    • To take out the Graphics card fan it is necessary to disconnect the two Graphic card fan cables. Use a plastic opening tool to remove the cable.
  4. Hasee Z7M-i78172D1 Graphic Card Fan Replacement: step 4, image 1 of 1
    • Use a #0 Phillips head screwdriver and unscrew the five 7mm screws holding the fan in place.
  5. Hasee Z7M-i78172D1 Graphic Card Fan Replacement: step 5, image 1 of 2 Hasee Z7M-i78172D1 Graphic Card Fan Replacement: step 5, image 2 of 2
    • Lift the Graphics card fan out and replace with the replacement fan.
Zachary Gay
124 Reputation
1 Guide authored
USF Tampa, Team S6-G6, Eyestone Spring 2018 Member of USF Tampa, Team S6-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S6G6
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 397
