Havoc Heli IR LED Replacement
  1. Havoc Heli IR LED  Replacement, Havoc Heli IR LED: step 1, image 1 of 2 Havoc Heli IR LED  Replacement, Havoc Heli IR LED: step 1, image 2 of 2
    • Power off the controller before disassembly.
    • Place a small piece of tape over the Light button to prevent it from falling out in later steps.
    • Flip the controller over so the back is facing up.
  2. Havoc Heli IR LED  Replacement: step 2, image 1 of 3 Havoc Heli IR LED  Replacement: step 2, image 2 of 3 Havoc Heli IR LED  Replacement: step 2, image 3 of 3
    • Remove the battery compartment screw with a small Phillips screw driver.
    • Lift off the battery cover.
    • Remove the six AA batteries from the compartment.
  3. Havoc Heli IR LED  Replacement: step 3, image 1 of 3 Havoc Heli IR LED  Replacement: step 3, image 2 of 3 Havoc Heli IR LED  Replacement: step 3, image 3 of 3
    • Remove the remaining four screws with a small Phillips screw driver.
    • Flip the device over so the front is facing up.
    • Remove the front cover and place it to the left side.
    • Make sure to note the locations of the joysticks and other controls in case they fall out of place during this or future steps.
  4. Havoc Heli IR LED  Replacement: step 4, image 1 of 1
    • Lift up the red IR LED cover to remove it.
  5. Havoc Heli IR LED  Replacement: step 5, image 1 of 2 Havoc Heli IR LED  Replacement: step 5, image 2 of 2
    • Use the soldering iron and solder wick to remove the solder from the IR LED you're replacing.
    • Pull the LED out through the top.
  6. Havoc Heli IR LED  Replacement: step 6, image 1 of 2 Havoc Heli IR LED  Replacement: step 6, image 2 of 2
    • Insert the new LED into the slot.
    • Make sure that the short lead of the LED is on the right.
    • Use the soldering iron and solder to connect the new LED.
Michael Kent
128 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 12
All Time: 736
