Head Cleaning V4/V5
  1. Head Cleaning V4/V5, Setting the printer: step 1, image 1 of 2 Head Cleaning V4/V5, Setting the printer: step 1, image 2 of 2
    • With the printer powered on, enter the menu screen and select the "Config. Rápida" (Quick Setup) option.
    • In the quick settings, select the "Retreat Table" option.
  2. Head Cleaning V4/V5, Repositioning the table: step 2, image 1 of 3 Head Cleaning V4/V5, Repositioning the table: step 2, image 2 of 3 Head Cleaning V4/V5, Repositioning the table: step 2, image 3 of 3
    • When the table is in the position shown in the photo, press the Reset button on the left side of the machine, as shown.
    • Select the "Pré-aquecer PLA" (Preheat PLA) option from the quick settings menu.
  3. Head Cleaning V4/V5, Repositioning the head: step 3, image 1 of 2 Head Cleaning V4/V5, Repositioning the head: step 3, image 2 of 2
    • With the table in place, manually push the head to the center of the machine for easier handling.
  4. Head Cleaning V4/V5, Removing the nozzle: step 4, image 1 of 3 Head Cleaning V4/V5, Removing the nozzle: step 4, image 2 of 3 Head Cleaning V4/V5, Removing the nozzle: step 4, image 3 of 3
    • Position the 20mm Fork Spanner, as shown in the figure, locking the inside of the head in order to prevent the nozzle from spinning.
    • With the 7mm Fork Wrench, remove the nozzle from the head.
  5. Head Cleaning V4/V5, Removing the top PTFE: step 5, image 1 of 2 Head Cleaning V4/V5, Removing the top PTFE: step 5, image 2 of 2
    • With your hands, pull the PTFE tube from the head, pressing the black part of the piece where the tube is fitted.
  6. Head Cleaning V4/V5, Removing the inner PTFE: step 6, image 1 of 3 Head Cleaning V4/V5, Removing the inner PTFE: step 6, image 2 of 3 Head Cleaning V4/V5, Removing the inner PTFE: step 6, image 3 of 3
    • Positioning the bit in the indicated hole, push it down until the inner PTFE comes out from under the head (where the nozzle hole is).
  7. Head Cleaning V4/V5, Replacement and Cleaning: step 7, image 1 of 3 Head Cleaning V4/V5, Replacement and Cleaning: step 7, image 2 of 3 Head Cleaning V4/V5, Replacement and Cleaning: step 7, image 3 of 3
    • Finish removing the internal PTFE and replace it with a new one or clean it.
    • With the drill, clean the nozzle hole as shown in the picture.
    • Put the new inner PTFE in place as shown.
  8. Head Cleaning V4/V5, Reassembling the head: step 8, image 1 of 3 Head Cleaning V4/V5, Reassembling the head: step 8, image 2 of 3 Head Cleaning V4/V5, Reassembling the head: step 8, image 3 of 3
    • Replace the nozzle at the bottom of the head and the PTFE at the top, pushing it all the way down with your hands.
  9. Head Cleaning V4/V5, Returning the table to the initial position: step 9, image 1 of 2 Head Cleaning V4/V5, Returning the table to the initial position: step 9, image 2 of 2
    • Reposition the table, in the option "Home XYZ" of the menu, in the section of quick setup and wait for it to be in the position indicated by the figure
You are ready to continue your prints!
Special thanks to these translators:
pt en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Mousta Impressoras 3D
691 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 271
