Introduction
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Peel off both front side foam pads to uncover the speaker wires.
Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
Four 3.9 mm screws (two on each side)
Two 4.1 mm screws (one on each side)
