Minolta Dimage Xt Capture Button Replacement
  1. Minolta Dimage Xt Capture Button Replacement, Casing: step 1, image 1 of 3 Minolta Dimage Xt Capture Button Replacement, Casing: step 1, image 2 of 3 Minolta Dimage Xt Capture Button Replacement, Casing: step 1, image 3 of 3
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Capture Button Replacement: step 2, image 1 of 3 Minolta Dimage Xt Capture Button Replacement: step 2, image 2 of 3 Minolta Dimage Xt Capture Button Replacement: step 2, image 3 of 3
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt Capture Button Replacement, Capture Button: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Choosing the front half of the casing, locate the capture button on the top.
    • Using tweezers, apply pressure to the two black hooks (circled in red) while holding the button down from the outside of the case.
  4. Minolta Dimage Xt Capture Button Replacement: step 4, image 1 of 1
    • The button will spring free. The capture device consists of the plastic button and a small metal spring.
    • The button can be reassembled by using the tweezers to place the spring rectangle-side down on the button and snapping the button back into place.
Reassemble the casing by reversing steps 1 and 2.
Megan Milam
56 Reputation
5 Guides authored
Clemson, Team 12-4, Benson Spring 2013 Member of Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 521
