Headphone Jack
  1. Headphone Jack, Battery: step 1, image 1 of 1
    • Unplug laptop from adapter and all other devices.
  2. Headphone Jack: step 2, image 1 of 1
    • Flip the laptop over with battery facing you.
  3. Headphone Jack: step 3, image 1 of 2 Headphone Jack: step 3, image 2 of 2
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. Headphone Jack: step 4, image 1 of 1
    • Pull battery out.
  5. Headphone Jack, Keyboard: step 5, image 1 of 1
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. Headphone Jack: step 6, image 1 of 1
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. Headphone Jack: step 7, image 1 of 1
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. Headphone Jack: step 8, image 1 of 1
    • Remove keyboard wire by popping latch under blue plastic
  9. Headphone Jack, Case: step 9, image 1 of 1
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. Headphone Jack: step 10, image 1 of 1
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. Headphone Jack: step 11, image 1 of 1
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. Headphone Jack: step 12, image 1 of 3 Headphone Jack: step 12, image 2 of 3 Headphone Jack: step 12, image 3 of 3
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. Headphone Jack, Headphone Jack: step 13, image 1 of 1
    • Use the spudger to lift the white tab
    • pull horizontally on the blue ribbon to disconnect the cable
  14. Headphone Jack: step 14, image 1 of 1
    • Use plastic pry tool to lift up on headphone jack assembly
Tyler Lirio
93 Reputation
1 Guide authored
USF Tampa, Team S11-G2, Cheng Spring 2018 Member of USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
4 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 53
All Time: 563
