Heyday Round Bluetooth Speaker Subwoofer Replacement
  1. Heyday Round Bluetooth Speaker Subwoofer Replacement, Heyday Round Bluetooth Speaker Disassembly: step 1, image 1 of 2 Heyday Round Bluetooth Speaker Subwoofer Replacement, Heyday Round Bluetooth Speaker Disassembly: step 1, image 2 of 2
    • Use a metal spudger to pry the fabric-covered top off of the speaker.
  2. Heyday Round Bluetooth Speaker Subwoofer Replacement: step 2, image 1 of 3 Heyday Round Bluetooth Speaker Subwoofer Replacement: step 2, image 2 of 3 Heyday Round Bluetooth Speaker Subwoofer Replacement: step 2, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the twelve screws around the perimeter of the inner plastic shell.
    • Remove the inner shell from the back case.
    • Don't yank or pull the shell case off the bottom case. There are cables connecting the two and they could be damaged if pulled.
  3. Heyday Round Bluetooth Speaker Subwoofer Replacement, Subwoofer: step 3, image 1 of 2 Heyday Round Bluetooth Speaker Subwoofer Replacement, Subwoofer: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Use curved tip tweezers to detach the connectors of two 2-prong Aux In/Out plugs extending from the subwoofer.
  4. Heyday Round Bluetooth Speaker Subwoofer Replacement: step 4, image 1 of 2 Heyday Round Bluetooth Speaker Subwoofer Replacement: step 4, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the four screws at the edge of each subwoofer to release them.
    • Remove both subwoofers.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 140
