Heyday Suitcase Turntable Lever Replacement
  1. Heyday Suitcase Turntable Lever Replacement, Baseboard: step 1, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
  2. Heyday Suitcase Turntable Lever Replacement: step 2, image 1 of 1
    • Use a metal spudger to pry the baseboard off of the case.
    • Be cautious of the cords and circuit located underneath the knob and the lever. Don't pull or yank the baseboard off.
  3. Heyday Suitcase Turntable Lever Replacement: step 3, image 1 of 2 Heyday Suitcase Turntable Lever Replacement: step 3, image 2 of 2
    • Disconnect the cords from the circuit board.
    • Take a picture beforehand so it's easier to put them back during reassembly.
    • Remove the baseboard.
  4. Heyday Suitcase Turntable Lever Replacement, Lever: step 4, image 1 of 2 Heyday Suitcase Turntable Lever Replacement, Lever: step 4, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the screw securing the plate that covers the lever.
    • Remove the plate blocking access to the lever.
  5. Heyday Suitcase Turntable Lever Replacement: step 5, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the plate securing the lever.
  6. Heyday Suitcase Turntable Lever Replacement: step 6, image 1 of 1
    • Pull the lever out of the front of the device.
Caroline D'Amato
565 Reputation
6 Guides authored
UMass Dartmouth, Team 2-1, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-1, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G1
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 140
