Heyday Suitcase Turntable Motor Replacement
  1. Heyday Suitcase Turntable Motor Replacement, Platter: step 1, image 1 of 1
    Tool used on this step:
    $3.99
    Buy
    • Unlock the front latches and open the turntable suitcase cover.
    • Using angled tweezers or a Halberd spudger, pry the spindle shaft from the spindle.
    • Be careful, as the spindle shaft may fly off in an unexpected direction.
  2. Heyday Suitcase Turntable Motor Replacement: step 2, image 1 of 1
    • Use both hands to gently lift the platter up and off of the turntable.
  3. Heyday Suitcase Turntable Motor Replacement, Baseboard: step 3, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
  4. Heyday Suitcase Turntable Motor Replacement: step 4, image 1 of 1
    • Use a metal spudger to pry the baseboard off of the case.
    • Be cautious of the cords and circuit located underneath the knob and the lever. Don't pull or yank the baseboard off.
  5. Heyday Suitcase Turntable Motor Replacement: step 5, image 1 of 2 Heyday Suitcase Turntable Motor Replacement: step 5, image 2 of 2
    • Disconnect the cords from the circuit board.
    • Take a picture beforehand so it's easier to put them back during reassembly.
    • Remove the baseboard.
  6. Heyday Suitcase Turntable Motor Replacement, Motor: step 6, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the screws connecting the motor and the baseboard.
    • The motor is located underneath the platter.
  7. Heyday Suitcase Turntable Motor Replacement: step 7, image 1 of 1
    • Flip the baseboard over.
    • Unplug the cable connecting the motor to the baseboard.
    • Remove the motor.
Caroline D'Amato
565 Reputation
6 Guides authored
UMass Dartmouth, Team 2-1, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-1, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G1
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 22
All Time: 283
