Heyday Suitcase Turntable Volume Knob Replacement
  1. Heyday Suitcase Turntable Volume Knob Replacement, Baseboard: step 1, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
  2. Heyday Suitcase Turntable Volume Knob Replacement: step 2, image 1 of 1
    • Use a metal spudger to pry the baseboard off of the case.
    • Be cautious of the cords and circuit located underneath the knob and the lever. Don't pull or yank the baseboard off.
  3. Heyday Suitcase Turntable Volume Knob Replacement: step 3, image 1 of 2 Heyday Suitcase Turntable Volume Knob Replacement: step 3, image 2 of 2
    • Disconnect the cords from the circuit board.
    • Take a picture beforehand so it's easier to put them back during reassembly.
    • Remove the baseboard.
  4. Heyday Suitcase Turntable Volume Knob Replacement, Volume Knob: step 4, image 1 of 1
    • Use a metal spudger to pry the volume knob off of the baseboard.
  5. Heyday Suitcase Turntable Volume Knob Replacement: step 5, image 1 of 2 Heyday Suitcase Turntable Volume Knob Replacement: step 5, image 2 of 2
    • Use your fingers to unscrew the nut securing the volume knob.
  6. Heyday Suitcase Turntable Volume Knob Replacement: step 6, image 1 of 1
    • Use a metal spudger to pry the power knob off of the baseboard.
  7. Heyday Suitcase Turntable Volume Knob Replacement: step 7, image 1 of 2 Heyday Suitcase Turntable Volume Knob Replacement: step 7, image 2 of 2
    • Use your fingers to unscrew the nut securing the power knob.
  8. Heyday Suitcase Turntable Volume Knob Replacement: step 8, image 1 of 1
    • Pull the circuit board down from the baseboard to separate them.
  9. Heyday Suitcase Turntable Volume Knob Replacement: step 9, image 1 of 1
    • To release the volume knob, desolder each of the eight solder joints.
    • Make sure to take proper safety precautions while operating soldering iron. For a review, take a look at the guide on How to Solder and Desolder Connections.
Caroline D'Amato
565 Reputation
6 Guides authored
UMass Dartmouth, Team 2-1, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-1, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G1
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 155
