High Heel Buckle Replacement
  1. High Heel Buckle Replacement, Elastic Strap Buckle: step 1, image 1 of 3 High Heel Buckle Replacement, Elastic Strap Buckle: step 1, image 2 of 3 High Heel Buckle Replacement, Elastic Strap Buckle: step 1, image 3 of 3
    • Cut through the remaining thread of the elastic strap.
    • Remove the strap buckle to adjust the position.
    • This step is only if the elastic strap is still attached by any little thread. If the buckle is already detached, skip to step two.
  2. High Heel Buckle Replacement: step 2, image 1 of 2 High Heel Buckle Replacement: step 2, image 2 of 2
    • Slide the end of the strap underneath the buckle frame without the center prong.
  3. High Heel Buckle Replacement: step 3, image 1 of 2 High Heel Buckle Replacement: step 3, image 2 of 2
    • Lift the center buckle prong vertically and place it into the center of the strap elastic.
  4. High Heel Buckle Replacement: step 4, image 1 of 1
    • Continue pushing the strap elastic down underneath the other side buckle frame.
  5. High Heel Buckle Replacement: step 5, image 1 of 2 High Heel Buckle Replacement: step 5, image 2 of 2
    • Fold the detached elastic strap together with the strap attached to the heel so that both straps are evenly lined up.
  6. High Heel Buckle Replacement: step 6, image 1 of 3 High Heel Buckle Replacement: step 6, image 2 of 3 High Heel Buckle Replacement: step 6, image 3 of 3
    • With a threaded needle, sew along the ends of the straps in order to enclose the buckle in place.
    • Avoid poking your fingers with the needle.
  7. High Heel Buckle Replacement: step 7, image 1 of 2 High Heel Buckle Replacement: step 7, image 2 of 2
    • Test out the buckle to ensure it is lined properly and can now strap the heel.
Finish Line
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 98
All Time: 11,529
