Hipstreet Titan Plus Motherboard Replacement
  1. Hipstreet Titan Plus Motherboard Replacement, Motherboard: step 1, image 1 of 2 Hipstreet Titan Plus Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Use the plastic opening tools to pry the screen from the back of the device.
  2. Hipstreet Titan Plus Motherboard Replacement: step 2, image 1 of 1
    • Use the spudger to remove the speaker from the back casing of the device.
  3. Hipstreet Titan Plus Motherboard Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the black adhesive strips from the wires using the tweezers, and set the strips aside.
  4. Hipstreet Titan Plus Motherboard Replacement: step 4, image 1 of 2 Hipstreet Titan Plus Motherboard Replacement: step 4, image 2 of 2
    • Use the spudger to release three (3) black clips connecting the components to the motherboard.
  5. Hipstreet Titan Plus Motherboard Replacement: step 5, image 1 of 2 Hipstreet Titan Plus Motherboard Replacement: step 5, image 2 of 2
    • Unscrew the motherboard using a J0 Phillips head screwdriver.
  6. Hipstreet Titan Plus Motherboard Replacement: step 6, image 1 of 2 Hipstreet Titan Plus Motherboard Replacement: step 6, image 2 of 2
    • Use the metal spatula to remove the battery from the back of the screen.
  7. Hipstreet Titan Plus Motherboard Replacement: step 7, image 1 of 2 Hipstreet Titan Plus Motherboard Replacement: step 7, image 2 of 2
    • Use the soldering iron to heat the end of the wires connecting the speaker to the motherboard.
    • Apply heat until the wires are free.
  8. Hipstreet Titan Plus Motherboard Replacement: step 8, image 1 of 2 Hipstreet Titan Plus Motherboard Replacement: step 8, image 2 of 2
    • Using the soldering iron, apply heat to the end of the wires until they are free from the motherboard.
  9. Hipstreet Titan Plus Motherboard Replacement: step 9, image 1 of 2 Hipstreet Titan Plus Motherboard Replacement: step 9, image 2 of 2
    • Now that the battery and speaker are removed, the black clips are undone, and the motherboard is unscrewed, remove the motherboard.
Kari Cannon
500 Reputation
4 Guides authored
UMass Dartmouth, Team 1-1, Miles Fall 2015 Member of UMass Dartmouth, Team 1-1, Miles Fall 2015
UMASSD-MILES-F15S1G1
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 367
